1Back to top Go down   Problemas ??? Empty Problemas ??? Mon Sep 14, 2020 5:47 am
César Santos
César Santos
Hi...
Now I started to do maintenance on the bike, I face two problems:
1- Oil leak in front of the engine, I think of the oil and water pump area, so I read it is common, I will take the opportunity to replace the seal and see the pump shaft.
2- A noise that comes from the clutch area when I decelerate and tighten the clutch, until relantim with the disengaged bike if it accelerates little if there was no, if it accelerates hard when I decelerate it makes a crash, what will it be? The clutch is functioning correctly.
Meanwhile I put a video.
Where can I buy quality material at a good price for shipping to Portugal?
Hug and good laps ...
2Back to top Go down   Problemas ??? Empty Re: Problemas ??? Mon Sep 14, 2020 6:33 am
moriarti
moriarti
Hi Cesar,Oil leak yes water/oil pump seals,Clutch noise,Have you inspected DRIVESHAFT splines/joint,this might be the problem.Motorworks.co.uk are a very good company for parts and service.Happy days Very Happy
3Back to top Go down   Problemas ??? Empty Re: Problemas ??? Tue Sep 15, 2020 10:33 am
I think you need to start disassembling the drive train from the rear wheel. Inspect everything as you go.
Could be the universal joint.
It always helps if you note your model as there are slight differences.
 Problemas ??? Austra12    Fuel:  95 Octane
4Back to top Go down   Problemas ??? Empty Re: Problemas ??? Tue Sep 15, 2020 5:33 pm
César Santos
César Santos
Thank you in advance for your help.
The strange thing is that it doesn't always do.
I'm going to do this inspection, I may find the problem.
Another problem I think I have is the fuel pump, I have no problem, the bike always goes well and the ride is ok, but I always hear a noise "inject" intermittently. It's normal?
Thank you
5Back to top Go down   Problemas ??? Empty Re: Problemas ??? Wed Sep 16, 2020 5:07 am
Yes. While the engine is running, the fuel pump is also running. It does not stop.
6Back to top Go down   Problemas ??? Empty Re: Problemas ??? Wed Sep 16, 2020 12:37 pm
César Santos wrote:Meanwhile I put a video.
Put the video on YouTube, César, then put a link to it here.
7Back to top Go down   Problemas ??? Empty Re: Problemas ??? Sat Sep 19, 2020 3:34 pm
César Santos
César Santos
Good afternoon,
This is the noise I said.
I leave video link
https://www.youtube.com/watch?v=nUAXdZ8X_9g
Thank you
8Back to top Go down   Problemas ??? Empty Re: Problemas ??? Sat Sep 19, 2020 8:57 pm
Has hecho un video Privado en YouTube. Por favor, cambie el video a Público haciendo clic la palabra Público en su menú de YouTube para que todos puedan verlo sin ser miembros de Youtube.
9Back to top Go down   Problemas ??? Empty Problemario Sat Sep 19, 2020 9:04 pm
daveyson
daveyson
I can't see the video, it says private. I sometimes had that, but it wasn't a problem, I just had to get used to the gearbox with practice.
 ~120,000 km
10Back to top Go down   Problemas ??? Empty Re: Problemas ??? Sat Sep 19, 2020 9:15 pm
César Santos
César Santos
Can see the vídeo now?
11Back to top Go down   Problemas ??? Empty Problem Sat Sep 19, 2020 9:43 pm
daveyson
daveyson
Yep I see it now. Listen from many different points to find where the noise is coming from. If it's louder with the petrol cap opened, remove the cap assembly, look closer in the tank. My first thought was of a fuel hose tapping against something in the tank while accelerating, although it sounds very deep.
 ~120,000 km
