1Back to top Go down   Coolant refill Empty Coolant refill Sat Nov 07, 2020 6:22 pm
Pearlsilver
Pearlsilver
I decided to get another BMW but I had to keep my K100RS.
Having had this K1300 for about a year, when the radiator decided to start leaking,
fitting a new one requires the vacuum method, but a few are suggesting a method without
vacuum - anyone out there that has filled the coolant without using the vacuum method?
If so can it be done safely and successfully?
I am aware of a method of having bike on side stand a slowly filling the radiator and waiting for coolant to come
out the other side of the bike through the water pump bleed nipple.
thanks in advance.
Nwoody
Barry Island.
2Back to top Go down   Coolant refill Empty Re: Coolant refill Sun Nov 08, 2020 1:01 pm
I tried the non-vacuum method on my '09 K1300GT. After draining the radiator, removing it to access the sparkies and for a valve clearance check, cleaning out the numerous smashed insects, and straightening the many bent 'fins', it took three days of topping off, allowing the fluid to slowly fill the cavities in the engine, coolant overflow and radiator. Three days?! Just when the system seemed to have enough coolant contained within I'd start 'er up and let it idle 'til the fan cycled on...but it would never cycle off, so I'd stop it and let it sit overnight to cool thoroughly, then remove the pressure cap from the radiator. Side stand or not, once again, the fluid would be low and seem to require a bit more so in more would go, until the radiator overflow catch bottle would burp it out - I have to say that at no time during this trial and error was I able to get any of the renewed coolant to escape out of the two air bleeds on the water pump or radiator - and so in the end I bought a vacuum bleeder kit ($30 on eBay), hooked it up to my air compressor and did it the right way in about ten minutes' time.
Coulda, shoulda, woulda. Who here on the forum had the quote "never enough time to do it right but always enough time to do it again"...I think it was Blakey?
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, #1 '06 K1200R, #2 '06 K1200R, '07 K1200R, '09 K1300GT, '13 R1200RT-P & 2022 S1000XR
"Do you ever read any of the books you burn?" "That's against the law!" "Oh, of course."
~Ray Bradbury, science-fiction writer (22 August 1920 - 2012)
3Back to top Go down   Coolant refill Empty Re: Coolant refill Sun Nov 08, 2020 1:11 pm
brickrider2
brickrider2
Can someone explain what the vacuum method is? TIA
1996 K1100LT
5Back to top Go down   Coolant refill Empty Re: Coolant refill Sun Nov 08, 2020 2:04 pm
brickrider2
brickrider2
Good video.  Thanks.
Filling the radiator seems to be an issue with K1300, I guess.  When I serviced the radiator on my K1100 I simply filled it at the radiator as best I could then, in subsequent days, I topped up the over flow tank a few times and all seems good.
1996 K1100LT
6Back to top Go down   Coolant refill Empty Re: Coolant refill Sun Nov 08, 2020 2:32 pm
mike d
When I did my K1100 it was much the same, slow fill, then check and top if required.  Very different for the K4x bikes.
Mike
7Back to top Go down   Coolant refill Empty Coolant refill Sun Nov 08, 2020 2:58 pm
Pearlsilver
Pearlsilver
Two Wheels Better wrote:I tried the non-vacuum method on my '09 K1300GT. After draining the radiator, removing it to access the sparkies and for a valve clearance check, cleaning out the numerous smashed insects, and straightening the many bent 'fins', it took three days of topping off, allowing the fluid to slowly fill the cavities in the engine, coolant overflow and radiator. Three days?! Just when the system seemed to have enough coolant contained within I'd start 'er up and let it idle 'til the fan cycled on...but it would never cycle off, so I'd stop it and let it sit overnight to cool thoroughly, then remove the pressure cap from the radiator. Side stand or not, once again, the fluid would be low and seem to require a bit more so in more would go, until the radiator overflow catch bottle would burp it out - I have to say that at no time during this trial and error was I able to get any of the renewed coolant to escape out of the two air bleeds on the water pump or radiator - and so in the end I bought a vacuum bleeder kit ($30 on eBay), hooked it up to my air compressor and did it the right way in about ten minutes' time.
Thanks for the info - I think I'll get a vacuum system just to make sure and as you say save time in the long run.
Nwoody
Barry Island.
8Back to top Go down   Coolant refill Empty Coolant refill Sun Nov 08, 2020 3:00 pm
Pearlsilver
Pearlsilver
brickrider2 wrote:Good video.  Thanks.
I have a K100RS and they like your K1100 are filled just like a car, fill up and run the engine until all air is out, after thermostat has opened and fan cut in.
Nwoody
Barry Island.
