1Back to top Go down   Fuel pump replacement today.  Empty Fuel pump replacement today. Mon Jan 18, 2021 1:55 pm
SniperX
SniperX
I have the old one out, new one is hooked up to wires. If I turn the key on is the hot side supposed to go hot with just the key on? I tested power with the old pump and I read no voltage at the positive and negative wires on the old pump with the key in the on position. Is there a fuel pump specific fuse, or a relay?
2Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 2:10 pm
You don't mention the bike type. But the fuel pump does have a fuse and does have a relay.
On some Ks the fuel pump and horn relay are interchangeable.
1983 K100RS 0011171 Fricka 606 Alaska Blue 29,495 miles Damn K Pox Its a Bat outta Hell Now 37,190 miles.
3Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 2:14 pm
It won't go hot until you press the starter button. You need to include model and year of your Brick in your profile signature.
4Back to top Go down   Fuel pump replacement today.  Empty OOOPS! Mon Jan 18, 2021 2:33 pm
SniperX
SniperX
All that used to be in my signature... Anyway it's a 1985 K100RT, 86K original miles, and I am replacing the packing and such as well as the pump, filter, and in tank submersible lines....
1985 BMW K100RT, 2006 Ducati ST3, 1996 Honda CBR1000f, 2001 Honda XR400r
5Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 2:35 pm
2 valve Jetronic bikes power up the fuel pump when the start button is pressed.
The later 4 valve Motronic bikes turn on the fuel pump for two seconds when the key is turned on.
6Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 2:38 pm
SniperX
SniperX
@Point-Seven-five wrote:2 valve Jetronic bikes power up the fuel pump when the start button is pressed.
Ok, sounds good. I'll test it with the start button pressed. Will it hurt anything if I just do a quick voltage test whilst the pump is in my hand as opposed to being installed? Just for a second or three?
7Back to top Go down   Fuel pump replacement today.  Empty Fixed my signature Mon Jan 18, 2021 2:39 pm
SniperX
SniperX
My bike information is in my signature now.
8Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 3:13 pm
You can do a quick test without doing harm. However you don't want to create any sparks from either the wiring connections or from the pumps commutator. Sparks can result in a BIG BADDA BOOM. Wrapping a damp cloth around the pump may reduce the chance of blowing both you and your Brick up. Take care.
9Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 4:25 pm
SniperX
SniperX
@MartinW wrote:You can do a quick test without doing harm. However you don't want to create any sparks from either the wiring connections or from the pumps commutator. Sparks can result in a BIG BADDA BOOM. Wrapping a damp cloth around the pump may reduce the chance of blowing both you and your Brick up. Take care.
I completely drained the petrol, and even cleaned out the entire inside of my tank as well. So no fuel to go BOOM! Thanks for the warning though!
10Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 4:30 pm
But the 4v needs the side stand up for this to happen.
11Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 4:41 pm
SniperX
SniperX
I work on it on the center stand, it's always started that way.
12Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 5:25 pm
a quick test wont harm anything
if looking for a longer test , just remember that fuel passing through the pump cools the whole thing , bearing wear could be an issue running it for long periods dry , windings also on the armature
just a heads up
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OFuel pump replacement today.  Au-log10
13Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 5:26 pm
SniperX
SniperX
I'd know right away.
14Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Mon Jan 18, 2021 5:41 pm
@SniperX wrote: Is there a fuel pump specific fuse  . . .?
Yes.
Fuel pump replacement today.  Scree122
1995 K75 81,000 miles
Fuel pump replacement today.  Usa-lo10
15Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Tue Jan 19, 2021 9:28 am
moriarti
moriarti
#9 NEVER EVER IS THE THE TANK FULLY PERGED AND FUME FREE  affraid affraid affraid
You must use Co 2 gas or steam into the tank before and during working on it.
Sorry for being an old Scary Pants but i have the Tshirt with SCORCH marks.By its nature  ALUMINIUM holds petroleum residue more than steel Thats why spirit tankers are S/STEEL.
Better to be safe than Singed  Fuel pump replacement today.  112350
1984 k100 rs red/black VIN  0004449
16Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 1:03 pm
SniperX
SniperX
The old packing for the pump mount is different than the new one...or vica verse. Is the new one the pictured one with the cut out on one side, going to be alright? Everything fits fine....
17Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 1:09 pm
SniperX
SniperX
The old packing for the pump mount is different than the new one...or vica verse. Is the new one the pictured one with the cut out on one side, going to be alright? Everything fits fine....Fuel pump replacement today.  Img_2014 Fuel pump replacement today.  Img_2014
Fuel pump replacement today.  Img_2015 Fuel pump replacement today.  Img_2014
18Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 3:39 pm
@SniperX wrote:The old packing for the pump mount  is different than the new one...or vica verse. Is the new one the pictured one with the cut out on one side, going to be alright?
That rubber component is called the vibration damper. Because it is next to both locking tabs, it will probably provide enough tension when the unit is locked into in the assembly to prevent vibration.
Who is the manufacturer?
19Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 4:14 pm
JiiPee63
JiiPee63
What could go wrong ?, Sorry, I had to Fuel pump replacement today.  652573
1986 K100RS 0089906 (Black 608)
Ex - 1984 K100RS (white), 1986 Suzuki GR650
20Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 4:28 pm
SniperX
SniperX
it is an original bmw part fische said it's the correct replacement
21Back to top Go down   Fuel pump replacement today.  Empty Re: Fuel pump replacement today. Wed Jan 20, 2021 8:11 pm
@SniperX wrote:it is an original bmw part fische said it's the correct replacement
That must be comforting. Smile Onward!
