1Back to top Go down   Fast idle after fan starts Empty Fast idle after fan starts Tue May 04, 2021 4:08 pm
nino
Hello, I have a normal idle (1000) until engine reach high temp in city stop and go traffic. Before fan start idle go up between 1500 - 2000. Any advice where to look? When fan out everything look usual. Bike is 1985 K 100. Tnx
2Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Wed May 05, 2021 5:45 am
Check the heat from the fan directing very hot air over the back of the radiator and throttle assemblies is not causing the throttle cable to not return properly. Check the clearance between throttle assembly and the clips on the intake rubbers. I had that happen on my K100LT.
That's an easy check before you look for other issues.
3Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Wed May 05, 2021 5:58 am
nino
Looks like something electric. Is it possible that working fan draw to much current and electric system try to compensate voltage by elevating idle. Everything looks OK except few moments before fan starts when idle rise to 1500 - 2000. When fan start to spin idle sometimes drop to 1000 rpm but sometimes stay high.
4Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Wed May 05, 2021 8:56 am
nino wrote: Is it possible that working fan draw to much current . . .
If that is happening, be prepared for an electrical fire.
5Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Wed May 05, 2021 10:37 am
Run a simple test.....pull the fan relay and see if you get an immediate drop in tick over.
6Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Wed May 05, 2021 7:35 pm
The same temperature sensor that is controlling the fan is also sending temperature information to the ECU.  When the temperature reaches 103°C, the fan relay engages and the fan turns on.  The ECU is also sensing the same temperature.  It shouldn't want to raise the idle speed but maybe some other component of the engine is feeding incorrect information to the ECU such that it is causing the injectors to run lean.  It could be the mass airflow sensor, or the Throttle position switch.
Do what Olaf suggests to eliminate the fan circuit.  Then if the idle increases as temperature increases, your problem would be mechanical and you should check the other components I mentioned.
7Back to top Go down   Fast idle after fan starts Empty Fast idle after fan starts Wed May 05, 2021 8:17 pm
daveyson
daveyson
Is this a fast idle after the fan starts, or the fan starts after a fast idle? Because it would be normal for the fan to start after a fast idle in city traffic.
If so, an air leak could cause a fast idle when the engine gets warm, so that would be another place to look.
 ~120,000 km
8Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Fri May 07, 2021 5:07 am
nino
Could it be aftermarket no name temperature sensor to send rich signal when temperature aproach 100 C? Anybody with experience on non original sensor? Thanks all
9Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Fri May 07, 2021 6:04 am
nino wrote:Could it be aftermarket no name temperature sensor to send rich signal when temperature aproach 100 C? Anybody with experience on non original sensor? Thanks all
Ah, that is likely to be your problem. Did the issue only happen after changing the sensor?
10Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Sat May 08, 2021 6:24 am
nino
Olaf, I dont remember if it happen after sensor change two years ago.
But I noticed that battery is weak, 12,01 Volts. One cell was empty. It doesnt receive current on idle, after idle run its impossible to start again. Could it be the cause of erratic idle? (yes Iam stupid)
11Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Sat May 08, 2021 8:35 am
moriarti
moriarti
Remove IT bin IT fit GENUINE BMW UNIT.Dont fit POOR quality parts, False economy my friend   roundel roundel
12Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Sat May 08, 2021 9:22 am
nino wrote: One cell was empty. It doesnt receive current on idle, after idle run its impossible to start again. Could it be the cause of erratic idle?
After you install a new battery—which you should certainly have on your immediate schedule because what you have now is junk—you'll find out.
13Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Mon May 10, 2021 6:13 am
nino
Finally it was dirty starter motor with almost dead brushes. It tortured battery (charging) which is 4 years old but still usable. Anyhow I ll change it tommorow.
Thanks all
14Back to top Go down   Fast idle after fan starts Empty Re: Fast idle after fan starts Mon May 10, 2021 9:05 am
Thanks for the update. Fast idle after fan starts 112350
