1Back to top Go down   Floating brake disc bobbin wear Empty Floating brake disc bobbin wear Mon Mar 29, 2021 7:11 pm
Recently having a front wheel fitted the tyre guy commented that the bobbins were well worn. I came home and compared them to a set on another bike and a spare set I bought secondhand but nearly new. I can't see much difference to be honest.
My question is how do you measure wear in the bobbins and when to change them?
Floating brake disc bobbin wear Ir-log11 88....May contain nuts!Floating brake disc bobbin wear Ir-log11
2Back to top Go down   Floating brake disc bobbin wear Empty Re: Floating brake disc bobbin wear Mon Mar 29, 2021 9:17 pm
Grab the floating disk and attempt to rotate it radially around the centre mount (i.e. in the same direction the wheel rotates).  The disk should not move radially at all.  If it does, the bobbins are worn.  Floating disks can move tangentially a little bit because they are designed to do that so that the pads can apply equal pressure to the disk.
