1Back to top Go down   charging light Empty charging light Tue Apr 20, 2021 3:49 pm
moriarti
moriarti
OK when starting from cold symptoms of low battery, slow cranking speed once started and run for a while will restart as normal. On last start-up charging light stayed on about half strength even when reved high. Alternator tested and found to be in good condition Starter removed and bench tested, Battery test shower 12.8v
when starter ran battery dropped by1.6v Starter ran smooth without undue effort.
when reassembled if problem persists what may be the  cause help and suggestions much appreciated Very Happy Very Happy Chatter
1984 k100 rs red/black VIN  0004449
2Back to top Go down   charging light Empty Re: charging light Tue Apr 20, 2021 5:40 pm
Starter removed, stripped, cleaned and bench tested.
You missed a bit Very Happy . Seriously though, you're describing a worn brushes problem.
3Back to top Go down   charging light Empty Re: charging light Tue Apr 20, 2021 5:53 pm
check condition of the positive lead from the alternator to the battery.  Terminals clean, no corrosion?  Terminals intact, no rotted terminals from battery acid or oxidation?  Positive cable intact, no breakage of strands within the cable?
What about battery ground cable.  Good contact with transmission? Good contact with battery?  Cable intact?
4Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 12:06 pm
moriarti
moriarti
Thanks to you both number one best mate with good eyes is on cable testing/cleaning, Starter is with man in large shed, me im on coffee duty Very Happy Very Happy I will post results when finished charging light 112350
5Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 12:30 pm
Corkboy
Corkboy
That used to happen to my K100, the charge light would glow dimly,
Finally tracked it down to when the (aftermarket) heated grips were on.
bit of a long shot I know, but you just reminded me.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
6Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 2:45 pm
Suzi Q
Suzi Q
Could be wrong, but isn't this the 'well-known' problem with voltage drop due to corrosion/age on the wire between the warning light and the alternator?
7Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 3:16 pm
1995 K75 81,000 miles
charging light Usa-lo10
8Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 3:41 pm
Suzi Q
Suzi Q
That's the one!  cheers
9Back to top Go down   charging light Empty Re: charging light Wed Apr 21, 2021 8:35 pm
That's... rather like using a sticking plaster instead of fixing the problem at source. affraid
10Back to top Go down   charging light Empty Re: charging light Sat May 01, 2021 10:59 am
moriarti
moriarti
To Conclude, Man in big shed says Starter in perfect working order, Put everything back together Bloody K STARTS AND RUNS PEFECTLY.  i can only think she didn't want to go ridding so threw a wobbly  Razz Razz
