Throttle Issues Sat May 01, 2021 6:04 am
GF Wollongong
Long story short: K100RS 1984
I have posted some of my machinations on other posts but I though I might collect things together here and bring the latest issue(s) to the fore.
Originally, I was pursuing idling issues - which might be labelled an air leak.
Bike might idle acceptably when first started but once hot, revs rose. I assumed this was due to "things expand when hot" ... so rubbers.
12 mths earlier, I had replaced rubber caps on TBs as well as idle screw o-rings
Serviced fuel injectors (filters, o-rings, flushed internals with carb cleaner)
New spark plugs. Caps pinched tight
Replaced valve shims - all set to correct settings, 1 out by .05 (my error)
Replaced upper and lower throttle body manifold rubbers. (definite evidence of lower rubbers 'o-rings' flattened - though no evidence of idle fluctuation when LPG, throttle cleaner or WD40 sprayed at the base)
Cleaned TBs - removed and cleaned butterflies and reset to same amount of movement when forced closed (ie. they all contact the TB throat at the same time. TPS clicking when throttle just opened
Replaced oetiker clamps
Checked flow on each of the TBs - managed to get them generally the same ... however...
Screws should be within 1 turn of each other. Mine are:
#1TB - 4 turns out
#2TB - 0 " "
#3TB - 3.5 " "
#4TB - 1.75 " "
Q: Am I to concentrate on getting the air flow the same or the screw settings? I would have assumed the former. So why the big difference ... valves not sealing properly?
At this point a test ride showed the bike running okay. Engine braking more noticeable. Still got an annoying vibration at 5000rpm - which makes me reluctant to keep it at this rate (though I did get it up to 6500rpm)
Did a compression test today and got the following settings
#1 - 160 (I assume it's PSI)
#2 - 170
#3 - 160
#4 - 180
When I had it all back together, I ran it and revved it and noticed a definite drop in revs when first quickly revving the engine up from idle - even cut out one time. This was a concern.
Elsewhere, I have the usual sprag clutch blues plus what sounds like a rattle coming from the engine (might be output shaft rivet play) but nothing that (I think) should be affecting idle issues.
Any things else I can address ... short of pulling the head and checking valve seats?
Any ideas appreciated
Regards
GF
- Engine momentarily missing when quickly revving
- Idle screw settings significantly different.
#1TB - 4 turns out
#2TB - 0 " "
#3TB - 3.5 " "
#4TB - 1.75 " "
#2 - 170
#3 - 160
#4 - 180
Regards
GF
