1Back to top Go down   Ebags new member to the brick world. Empty Ebags new member to the brick world. Wed Jul 07, 2021 5:43 am
Ebags
Ebags
Good Morning ,
Joined the forum yesterday and brought my 1st K100 RS 1984 yesterday, to add to the GSXR and C90 in the garage. It's been hiding in the back of a dry garage for 20 years and needs an overhaul and replacing bits that are missing.
Ebags new member to the brick world. 177912 Time to show it some daylight.
moriarti
moriarti
Welcome Aboard, Hope you have fun with the K,Once you are able to ride you will be pleasantly surprised Very Happy Very Happy
1984 k100 rs red/black VIN  0004449
Ebags
Ebags
Pleasant surprise I'm looking forward to. I need to source an ecu firstly then work my way through everything else.
Ebags wrote:Good Morning ,
Greetings!!!.
I got my 83 K100RS in 2018 after it had spent 17 years in a heated and dry boat shed.....
First thing to do is check the manufacture date. Reason is that 'early' K parts do not all fit 'very early' K bikes. In fact this can be tricky. If you have push button petrol cap [yes there is one] then you may find your brake calipers don't take the 'early' caliper rebuild kits. You need the kits off the 82/83 R bikes and not the K bike kits. Little things like that. Petrol tank is bolt on type, rear disk brake should be solid and not be slotted like the front ones [holes are ok, means its been replaced using EBC]......they got recalled for that but mine missed it. They crack suddenly and unexpectedly.
In do have an 84 K100RT so I can see the differences first hand.
Your centre stand may look good too, but they are very very prone to cracking due to internal corrosion and letting the bike over. Change it for a complete K1100 assembly, 4 bolts and its done. You risk breaking a mirror pod unit....and that's a lot more expensive. I did this on all my Ks.
moriarti
moriarti
ECU If you cant beg, borrow or steal one Very Happy Motorworks are a good company and they give 6 months warranty on used parts
Welcome Ebags Smile
Ebags new member to the brick world. Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
Ebags
Ebags
Greetings!!!.
Hi,
Thank you for the advice, the rear disc is solid and the fuel tank is key operated. I will check manufacturers date before I get started. Are you aware if the RT and RS ecu's are the same for this model ? I don't have the original for to identify to replace.
mike d
According to the part numbers on MAXBMW, the Jetronic unit (13611461828) is used on the K100, K100RS & K100RT models 1982 - 1989
Mike
Ebags
Ebags
Hi Mike, Thank you for the info.
