1 K100 ignition coil issue Thu Dec 09, 2021 2:26 pm
Haza
Hi there I’m currently having some issues I hope I can get some help with my ignition coil doesn’t seem to be getting the power it needs coil 1 has spark to plugs 1 and 3 but coil 2 will not produce spark with the current red and black wire However I have rules out a bad coil because I swapped the two coils wiring around and it then swapped so that coil 2 was the only 1 giving spark to plugs 2 and 4, does anyone know what this may be and how I can fix it looking online the wiring diagrams seem to point to this red and black problem wire going to the ignition control module or am I just being a bit thick and it’s likely just a wire rubber through somewhere?
