1Back to top Go down   K100 1986 electrical problem Empty K100 1986 electrical problem Sat Jan 15, 2022 3:38 am
thomo
thomo
Hi Guys
My K100RS 1986 has an electrical problem that i could do with a bit of help please !
horn doesn't work & when you press indicator switch all indicators come on but go off as soon as you let go of switch
It was all working fine a couple of weeks ago
took for a RWC & this is when i found out about this problem
does any one have a pic of the fuse box cover ? mine has disappeared
many thanks !
K100RS 1986
2Back to top Go down   K100 1986 electrical problem Empty Re: K100 1986 electrical problem Sat Jan 15, 2022 4:05 am
Chocolate
Chocolate
Hey good man !
K100 1986 electrical problem D9142610
K100 1986 electrical problem 10dc5010
K100 1986 electrical problem 5580c010
3Back to top Go down   K100 1986 electrical problem Empty Electrical problem Sat Jan 15, 2022 5:33 am
daveyson
daveyson
Removing fuse 7 (the bottom one) reproduces your symptoms, check it out.
 ~120,000 km
4Back to top Go down   K100 1986 electrical problem Empty Re: K100 1986 electrical problem Fri Jan 21, 2022 7:58 am
I have this same problem on my '96 K1100RS. What I found is that when the Hazard light switch is on, the indicators won't stay on, ie they cancel when you take your finger of the switch. This means that something in the hazard light circuit is shorting out the indicators.
Sorry, I can't help you past that because I've not bothered to find the fault. With the hazard light switch off it's not a problem.
Not sure if hazard lights are required for rego here in AU but the old girl passes each year.
Cheers Nigel
 K100 1986 electrical problem Austra12    Fuel:  95 Octane
5Back to top Go down   K100 1986 electrical problem Empty Electrical problem Fri Jan 21, 2022 8:41 pm
daveyson
daveyson
I spose your horn still works though, especially since it keeps passing the roadworthy.
Maybe the flasher unit is damaged.
 ~120,000 km
6Back to top Go down   K100 1986 electrical problem Empty Re: K100 1986 electrical problem Sat Jan 22, 2022 3:43 am
thomo
thomo
thomo wrote:Hi Guys
many thanks !
so after investigating the problem
the horns shorted the fuse ! put 2 x new horns & replaced fuse this has solved the issue
thanks for your help !
K100RS 1986
7Back to top Go down   K100 1986 electrical problem Empty Electrical problem Sat Jan 22, 2022 6:22 am
daveyson
daveyson
If the horns haven't been used in years, they might be jammed shut with rust, pressing the horn button like that a few times too many, might cause the fuse to blow.
One of my bricks (that sat for ten years) had jammed horns, I gave them some taps and shakes and wiggles and got them going again. You might be able to fix them and keep them for spares.
 ~120,000 km
8Back to top Go down   K100 1986 electrical problem Empty Re: K100 1986 electrical problem Sat Jan 22, 2022 7:47 am
Well, that's a hornblower......
K100 1986 electrical problem Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
9Back to top Go down   K100 1986 electrical problem Empty Re: K100 1986 electrical problem Sat Jan 22, 2022 7:58 am
I don't know whether to laugh, cry or just shake my head in disbelief at that pun.
