1Back to top Go down   K100 LT info required. Empty K100 LT info required. Wed Mar 09, 2022 9:42 am
AJR-118
AJR-118
I have a small diameter Tube coming from the left hand side of the swing arm housing unit.  My initail thoughts were this is the second part of the Fuel tank reservior tubing.
If anyone can confirm what this is I would apprecite it.
I have pictures but it says no pictures below.  Can I add a picture of this small bore tubing?
http://forum.kforum-tech.com/members-upload/uploads/Presentation1.ppt
Thanks in advance Andy
2Back to top Go down   K100 LT info required. Empty Re: K100 LT info required. Wed Mar 09, 2022 10:55 am
Tubes coming down at the swing arm can be the drain from the fuel overflow/cap drain receiver cup located under the petrol tank on the right hand frame spine. The tank has 2 drain exits under it, one for the water drain hole to the left of the petrol cap, and a second vent/overflow from inside the tank. The little plastic cup has a drain tube from it to the right hand side of the rear wheel. There is also a drain tube from the battery [if lead acid fitted] that tends to be on the left of the rear wheel.
3Back to top Go down   K100 LT info required. Empty K100 LT info required. Wed Mar 09, 2022 11:03 am
AJR-118
AJR-118
Hi Olaf,
I am assuming this is lead acid battery drain tube then.  Could you open the ppt I uploaded?  Cheers Andy
4Back to top Go down   K100 LT info required. Empty K100 LT info required. Wed Mar 09, 2022 11:31 am
AJR-118
AJR-118
K100 LT info required. Tube111K100 LT info required. Tube211K100 LT info required. K100_c10
Sent a latest picture of the Build too.  I haven't a clue what this pipe is for?  I also have the tank overflow reservior catcher and pipe on the other side.
If any of you guys can help much appreciated, cheers all.
Thanks Laitch for the uploading pictures instructions.  Big thumb
5Back to top Go down   K100 LT info required. Empty Re: K100 LT info required. Wed Mar 09, 2022 11:57 am
Old school. From the parts fiche at MaxBMW:
K100 LT info required. Lead_a10
6Back to top Go down   K100 LT info required. Empty K100 LT info required. Wed Mar 09, 2022 12:07 pm
AJR-118
AJR-118
Thanks Buddy, much appreciated.
