I few K Kronies are requiring a workshop day. Due to Matt and Gary going on a Kurfari in early August I thought probably late August and on a Sunday. Please let me know what jobs you require doing and if you are attending?
2Back to top Go down   Next SE Kweensland K Kronies WorKshop. Now the 28th of August. Empty Re Workshop Day Thu Jul 14, 2022 12:26 am
Bruce Petterson
Bruce Petterson
Hi Martin.   Grease the shaft is my work that is needed.    Thanks again.
I will be attending.   What day/date ?
Kind regards Bruce
Bruce Petterson wrote:Hi Martin.   Grease the shaft is my work that is needed.    Thanks again.
Kind regards Bruce
 Geez what sort of workshop is this when people are getting their shaft greased  ???
1986 K100 RS Motorsport
#### K100 RS Project
2011 R1200 GS
Matt are you volunteering to grease Bruce's shaft. Next SE Kweensland K Kronies WorKshop. Now the 28th of August. 723598 He will be supplying his own grease.  Next SE Kweensland K Kronies WorKshop. Now the 28th of August. 652573 Due to you having to work in order to support SSD and I I've made it on a Sunday and at the end of August. Will you be attending?
Mick67
Mick67
Thanks Martin.
I will be attending. Thinking about an instrument cluster overhaul - GPI and Clock displays bleeding, sticky speedo and clunky tripmeter gears, also a good clean up as hasnt been opened since I've had it - 18yrs.
Might take me some time to gather parts, so may not be ready for the day.
Happy to assist others as required.
Mick
K100RS 1984
VIN 0013414
Mick I have the parts.
Mick67
Mick67
Goodo. See you then if not before. We'll work something out re parts.
Mick
K100RS 1984
VIN 0013414
8Back to top Go down   Next SE Kweensland K Kronies WorKshop. Now the 28th of August. Empty Parts Thu Jul 21, 2022 4:41 am
Bruce Petterson
Bruce Petterson
Of course Martin has the parts . . . He could jolly near build another K bike with all the parts he has.
Bruce
Kind regards Bruce
That's them Northerners, Matt.  Theys always was a bit funny.
You're safe with us Southerners in the chain gang.  Weez just like to get lubricated.   (o)
Due to Matts busy schedule he is unable to attend any of the proposed dates. So at this stage it is planned for the 28th of August. I'm currently awaiting speedo gears which should hopefully be here by the 28th. Proposed works are two speedo overhauls and a driveshaft spline check and grease. If any other Kronies require work or are attending please let me know so Bruce's lovely  wife and my lovely wife can work out the food. Attendees at this stage Dan, Mick, SSD, Bruce, Vic.
Jamie64
Jamie64
Hi Guys
I will be there to assist with anything i can.
If we have time i too could do with a spot of grease in the tail section.
Chears Jamie
Bugger
I Cant make the 28th
2011 R1200 GS
