1Back to top Go down    Fuel Pump Sleeve Empty Fuel Pump Sleeve Thu Jul 21, 2022 11:18 am
pendullumx
pendullumx
Anybody got an slick ideas on how to fit the white plastic fuel pump sleeve into the tank?
Pushing like hell on the pump but the thicker clip on the forward (and harder to get to) end
of the tank but it does not want to click in.  Thin rear clip will click in with screwdriver blade
pushing on it.
2Back to top Go down    Fuel Pump Sleeve Empty Re: Fuel Pump Sleeve Thu Jul 21, 2022 12:34 pm
Maybe you should rotate the sleeve 180º and try again. You shouldn't need to push on the pump.
3Back to top Go down    Fuel Pump Sleeve Empty Re: Fuel Pump Sleeve Thu Jul 21, 2022 1:41 pm
Laitch wrote:Maybe you should rotate the sleeve 180º and try again. You shouldn't need to push on the pump.
One side of the plastic is rounded and one is cut off. I had a tank change last week and can tell you it fits only one way. as said rotate it 180 degrees.
