1Back to top Go down   K75 Ignition switch positions Empty K75 Ignition switch positions Thu Nov 24, 2022 3:11 am
Flippit
Flippit
Hey Guys,
Just curious as my bike is modified using original switch the positions of what they do.
Mine seems to have 4 positions.
1 - off
2 - power
3 - off (doesn’t click into this spot really)
4 - power
2 & 4 seem to do the same thing where there’s power to blinkers, horn and will start the bike.
Curious to know if a standard bike is the same and more so if 2 & 4 are identical ? Seems odd.
Cheers,
Phil
2Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Thu Nov 24, 2022 5:46 am
It's possible someone has re-soldered the wires underneath as I can't think of any other way to get that combination. Also; your third position is probably just wear in the brass contacts.
3Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Thu Nov 24, 2022 9:21 am
From BMW's K75 Rider's Handbook:
K75 Ignition switch positions Scree219
4Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Thu Nov 24, 2022 4:47 pm
Flippit
Flippit
Dai wrote:It's possible someone has re-soldered the wires underneath as I can't think of any other way to get that combination. Also; your third position is probably just wear in the brass contacts.
Yep that’s what I’m thinking where who ever modified the bike prior to my ownership has made position 2 & 4 identical instead of how it should
Have been in diagram displayed by the post above.
Position 3 as you said just feel like wear you’re right !
5Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Fri Nov 25, 2022 7:24 am
Pull the ignition switch and check underneath - the pins are numbered. It should be:
Red - 30
Green - 15
Slate (grey) - 58A
Slate/blue - 58E
6Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Fri Nov 25, 2022 4:12 pm
K75 Ignition switch positions MDC1ALD
7Back to top Go down   K75 Ignition switch positions Empty Re: K75 Ignition switch positions Sat Nov 26, 2022 7:54 am
Thanks Duck. You can never find a picture when you want one.
