1Back to top Go down   K75 Stand washer Empty K75 Stand washer Tue Nov 01, 2022 10:33 am
JGT
JGT
K75 Stand washer B0000910
Removed the stand to clean it up and found these washers missing. How thick are they and what do they do?
2Back to top Go down   K75 Stand washer Empty Re: K75 Stand washer Tue Nov 01, 2022 12:31 pm
What parts diagram are you looking at? Got a link?
At Real OEM those are grayed out for all K75 models - which means that part is not used on the selected vehicle.
K100s and K1100LTs have spacer bushings for the center stand bracket but other Ks do not. K100s just have a washer there but K1100LTs have a thicker bushing.
3Back to top Go down   K75 Stand washer Empty Re: K75 Stand washer Tue Nov 01, 2022 1:01 pm
At the MaxBMW fiche one diagram can be used for a few different models. If the part in question isn't used on a model, its part number will be omitted from the part list below the diagram. If it is used but isn't available, the letters NA will be in the Each column of the list.
4Back to top Go down   K75 Stand washer Empty Re: K75 Stand washer Tue Nov 01, 2022 1:28 pm
Aside from being faster and easier to navigate, greying out not used parts is another reason why I prefer using Real OEM to look up part numbers.  The prices and availability are way out of date so once I find the part number(s) I look them up at Max.
https://shop.maxbmw.com/fiche/PartsSearch.aspx
5Back to top Go down   K75 Stand washer Empty Re: K75 Stand washer Tue Nov 01, 2022 1:44 pm
JGT
JGT
I'm looking at MAXBMW and the one Fiche covers all naked K75's.
Thanks Laitch that explains it.
6Back to top Go down   K75 Stand washer Empty Re: K75 Stand washer Thu Nov 17, 2022 5:26 am
I'm sure I've seen different sizes on those washers from standard 2mm to 4mm the difference I'm led to believe is the K75 has a 17" and an 18" rear wheel and centrestand activation is equalled via the different thickness's
