Number of posts : 12027
If there is a groove you can detect with your fingernail after the shaft has been cleaned then it is RS. Quite often some discolouration or material left from a non lubricated seal will disguise a good shaft or the exposed part of the shaft is pitted by rust but the seal lip position is OK.
I have at times used a shaft that has a groove with success but only after careful inspection and considering the cost of a new shaft, which on some machinery can be in the 10s of thousands of dollars. It's sort of a " captains call"
