1Back to top Go down   Crankcase breather Empty Crankcase breather Thu Mar 02, 2023 6:30 pm
Basic2
Basic2
Does anyone have a drawing/photo of what's at the bottom of the crankcase breather port on the K100 2V engine? I may have dropped a screw into the crankcase breather port while replacing the "Z" tube and I'm wondering how deep into the engine it could fall. I've looked down the crankcase breather port but can't see it.
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
2Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 6:39 pm
Yes.......back soon   just have to get onto the compiter
3Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 6:46 pm
Basic2
Basic2
Thanks Charlie.
K100 Basic 2
Marakesh Red
4Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 7:04 pm
in two parts , as i have the bell housing off Gerty at the moment
thats a bad issue , because just below the breather tube is the intermediate gear that runs off the starter , then meshes with the sprag clutch .
however the screw may have lodged in a section just below the breather port on the bell housing side
i supose a magnetic pick up tool will have some issues in as much as the idler - intermediate gear is also steel but you may get lucky ? if you come from the breather tube ,  but perhaps could be lucky if you go in the starter port ?
likely the screw has gone all the way to the bottom of that housing ,,,,,  with luck ?
pic 1 engine side
Crankcase breather 20230310
pic 2 bell housing side starter gear removed
Crankcase breather 20230311
pic 3 bell housing side with gear installed
Crankcase breather 20230312
hope it helps , and good luck
5Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 8:34 pm
Basic2
Basic2
Awesome, thanks Charlie. Just bought a cheap inspection camera from Bunnings so I'll try going in through the breather port.
K100 Basic 2
Marakesh Red
6Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 10:01 pm
Basic2
Basic2
Would taking the sump off allow access?
K100 Basic 2
Marakesh Red
7Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 11:08 pm
I would get a tiny rare earth magnet with a hole in it and tie it onto some fishing line. Then drop it down the hole to see if it will grab the screw and then carefully extract it
Like this 8x3:
https://www.aliexpress.us/item/3256803926580811.html
8Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 11:09 pm
Nope      sorry to say.
That v shape is the limits of sump or internal engine and the clutch housing
9Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 11:13 pm
Dropping the magnet on fishing line will just have it stick itself to the first piece of ferrous metal it comes near.  It will never get to the screw if it's more than a half inch down the hole.
10Back to top Go down   Crankcase breather Empty Re: Crankcase breather Thu Mar 02, 2023 11:39 pm
Point-Seven-five wrote:Dropping the magnet on fishing line will just have it stick itself to the first piece of ferrous metal it comes near.  It will never get to the screw if it's more than a half inch down the hole.
True. Maybe put it on the end of some solid copper wire so that you can bend the wire and direct it. (Like a piece of Romex.)
11Back to top Go down   Crankcase breather Empty Re: Crankcase breather Fri Mar 03, 2023 1:10 am
Basic2
Basic2
Found! The screw was in behind the throttle body for cylinder 4 and not easy to spot.
Thanks for the responses/suggestions.
K100 Basic 2
Marakesh Red
12Back to top Go down   Crankcase breather Empty Re: Crankcase breather Fri Mar 03, 2023 6:53 am
Crankcase breather 723598 Crankcase breather 723598 Crankcase breather 723598
13Back to top Go down   Crankcase breather Empty Re: Crankcase breather Fri Mar 03, 2023 9:59 am
Nice   find
14Back to top Go down   Crankcase breather Empty Re: Crankcase breather Sat Mar 04, 2023 2:46 am
Basic2
Basic2
Yes, huge relief when i saw it.
K100 Basic 2
Marakesh Red
