1Back to top Go down   Slow blinkers Empty Slow blinkers Tue Apr 18, 2023 8:13 pm
Rockman
I've just got my K75C going again but the blinkers seem to be operating very slowly. Basically, when I first turn them on (either side) they light up for about 5 seconds before starting to blink. Even when they are blinking they seem very slow to me. I did note that once they had been used, the 5 second delay doesnt happen - still slow though.
Any suggestions as to why this is happening? I did check the bulbs and they are the correct wattage (21w). Battery is new and reads around 12.6V, alternator is charging at around 13.6-13.8v at ~2000rpm and above.
2Back to top Go down   Slow blinkers Empty Re: Slow blinkers Tue Apr 18, 2023 8:49 pm
Have you checked the blinker fluid level recently?
3Back to top Go down   Slow blinkers Empty Re: Slow blinkers Tue Apr 18, 2023 10:09 pm
Rockman
TacKler wrote:Have you checked the blinker fluid level recently?
Topped up with 250ml of electrons yesterday Very Happy
4Back to top Go down   Slow blinkers Empty Re: Slow blinkers Tue Apr 18, 2023 10:32 pm
Probably not the recommended fluid but at least it will stop the blinker fluid pump cavitating.
5Back to top Go down   Slow blinkers Empty Re: Slow blinkers Tue Apr 18, 2023 10:39 pm
Have come across this problem previously but it was on a borrowed moto at the time.
Someone will come across with the correct (non-liquid) solution soon.
6Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 12:03 am
Sounds to me Phil that the blinker control relay is the problem. If there are any bad connections anywhere in the blinker circuits then they speed up. I may have one here  I'll have a scout around.
7Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 12:05 am
Rockman
I noticed today that the lag time for them to start blinking is getting much less. Maybe its just lack of use or dirty connections. I'll pull the blinker unit out when I get a chance and clean it up. It could be 10 years since this thing has run. It was completely dead electrically when I got it.
8Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 12:33 am
Sometimes blinker issues occur if you don't use OEM blinker fluid. Third party blinker fluid often does not comply with BMW specs.
OR
Blinker gremlins are sometimes caused by a dirty starter. How many miles(kms) on the bike?
9Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 7:11 pm
Rockman
duck wrote:Sometimes blinker issues occur if you don't use OEM blinker fluid. Third party blinker fluid often does not comply with BMW specs.
OR
Speedo says 85k kms. Could be true.
Blinking is gradually increasing and is now up to ~50 blinks/minute and almost no lag time at the start - I'm not sure what it should be but maybe still a bit slow. I think I'll leave it be for the time being and see what happens.
10Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 7:45 pm
Rockman wrote:Blinking is gradually increasing and is now up to ~50 blinks/minute and almost no lag time at the start - I'm not sure what it should be . . . .
Congratulations! Looks like you've made the grade. cheers
AUSTRALIAN VEHICLE STANDARDS RULES - REG 104
Operation and visibility of direction indicator lights
 (1)     A direction indicator light fitted to a motor vehicle must:
        (a)     when operating, display regular flashes of light at a rate of not over 120, and:
            (i)     for a motor vehicle with 4 or more wheels – at least 60, flashes a minute; and
            (ii)     for another motor vehicle – at least 45, flashes a minute; and
        (b)     be able to be operated by a person in the normal driving position; and
        (c)     be wired to an audible or visible device in the vehicle that tells the driver that the direction indicator light is operating; and
        (d)     flash at the same time and rate as any other direction indicator lights fitted on the same side of the vehicle.
11Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 7:58 pm
Rockman
Thanks for looking that up for me. Saved me the effort.
12Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 8:11 pm
Just keep in mind your blinker rate won't keep you from being busted by the law if you're riding navasana, unless that's normal. Smile
13Back to top Go down   Slow blinkers Empty Re: Slow blinkers Wed Apr 19, 2023 10:46 pm
Rockman
Laitch wrote:Just keep in mind your blinker rate won't keep you from being busted by the law if you're riding navasana, unless that's normal. Smile
Had to look that up. Not at all likely I'd say Smile
14Back to top Go down   Slow blinkers Empty Re: Slow blinkers Tue May 02, 2023 3:52 am
Here it is.  Just for those sceptics out there who had trouble locating some.  Comes in a super sized 16 oz. container, so you won't run out.  Get's you back on the road in no time.
There is even an instructional video in the attached link at the bottom.  Well worth watching for you to fully comprehend it's installation and use.
Oh, and for all you with coffee'd racers, it's LED compatible!
https://www.dimecitycycles.com/dime-city-exclusive-formula-all-purpose-blinker-fluid.html
https://www.youtube.com/watch?v=bmHzD7gDfdo
