1Back to top Go down   Mirror Repair Empty Mirror Repair Tue Feb 22, 2011 9:47 pm
Chris H
Chris H
My K100LT mirrors are of the "pop off" type so there's a stud mounted on the faring and in the mirrors have the what may be called snaps. The snaps are loose in the mirrors and at least one has a broken ear and needs to be replaced so I don't loose my mirror. Where can I find the snap side of the business? Can't locate them on the parts fiche if they are even a "replaceable" part. Any suggestions?
Oh forgot to add, how do those darn mirrors come apart?
Chris
2Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Feb 23, 2011 1:05 am
Hi Chris,
Did you use the "search" utility on the forum use mirrors as the search term, do any of those 3 help? If you cannot get the snaps as you call them perhaps the solution would be to put a good squeeze of silicone rubber in the snap hole and push into place with tape or pressure to hold them in place for 24 hours. That wil;l retain them in place and still be easy to tear free if it needs to de-mount in an emergency.
3Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Feb 23, 2011 3:29 am
not a bad idea kbike .....good thinkin
4Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Feb 23, 2011 7:34 am
Chris H
Chris H
I had used the silicone insurance before, it actually stuck pretty well and was pretty snug removing the mirrors. Even if I do find the snaps I believe I'll use a little dab when I reassemble them. There are some fastener stores in the area, if I find some substitute I'll certainly post.
The two halves of the mirrors have been poorly glued together with what looks like Gorilla glue, thus the reason of question of how they come apart. I need to clean them up and re glue, any suggestions of technique or glue?
Chris
5Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Feb 23, 2011 9:33 am
i found that the plastic shell interlocks with a small step in the moulding of the mrror piece ....and someone had glued them up before me ,,,,causing interference when the shell mates up .....i took to it with a sharp knife to relieve the gunk inbetween to actually get a good mate again ...not sure of the best glue ....but i ended up useing something like a super glue (actually a 2 pack with a primer and the super glue stuff ) worked ok for me ...but im still not happy with it ....a couple of elastic bands held both halves in place whilst it cured ....
good luck chris
6Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Feb 23, 2011 6:32 pm
The snaps can be squeezed to give more pressure on the pins. Just use a pair of long nose pliers.
Gluing them with silicone may prevent them to pop up in case of the bike falling. If they don't pop out, you are in for a major rebuild of your fairing.
I personally prefer to replace a mirror than repairing cracks on the fairing.
Mirror Repair Frog15Mirror Repair Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   Mirror Repair Empty Re: Mirror Repair Fri Feb 25, 2011 5:31 am
Possibly superglue gel if the tolerances are good, never had them apart myself only changed the mirror in the housing.
8Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Mar 02, 2011 8:54 pm
reg_K100RS
Motobins.co.uk sell the wee clips for 90 pence each and various mirror parts
Not sur if the link will take you to the exact page but a quick search will
http://www.motobins.co.uk/bmw-parts.php?model=K%20Series
Edit:
Nope, it dont
using the above link, You'll need to also select
frame/fairing/mirrors
mirrors
mirror mounts
9Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Mar 02, 2011 10:18 pm
While we're speaking all things mirrors, if anyone can help me with info on how to attach the clips, I'd appreciate it!
10Back to top Go down   Mirror Repair Empty Re: Mirror Repair Fri Mar 04, 2011 11:11 pm
chrish8846
Any place in the US to get replacement mirror glass only??
Chris Hammond
1985 K100 RT sold
1992 K75RT still in Fixing mode
11Back to top Go down   Mirror Repair Empty Re: Mirror Repair Sat Mar 05, 2011 5:03 pm
Brickee
Brickee
Max BMW, vehicle trim section, # 46631455000. Unheated.
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
12Back to top Go down   Mirror Repair Empty Re: Mirror Repair Sun Mar 06, 2011 12:33 pm
chrish8846
Thanks for the info
Chris Hammond
1985 K100 RT sold
13Back to top Go down   Mirror Repair Empty Re: Mirror Repair Mon Mar 07, 2011 2:11 am
Cablebeacher
Hi Chris
I needed a replacement mirror glass last year and our local glass /window/mirror shop cut me two new ones with bevelled edges for about A$20 for the pair. It may be easier and cheaper option than OEM replacements???
Regards
Mal
14Back to top Go down   Mirror Repair Empty Re: Mirror Repair Mon Mar 07, 2011 6:25 am
I would not recommend installing a regular mirror.
I tried it too, but a regular mirror doesn't give you the same wide angle view as the original. I finally bought 2 new ones from BMW.
15Back to top Go down   Mirror Repair Empty Re: Mirror Repair Mon Mar 07, 2011 7:18 pm
Brickee
Brickee
I bought a truck replacement mirror(glass only) and tried cutting it to size. It's tricky as it's a convex mirror. After 2 tries I broke down and bought the OEM. Anyone know how to cut a convex mirror?
16Back to top Go down   Mirror Repair Empty Re: Mirror Repair Mon Mar 07, 2011 9:44 pm
The best way is to immerse it into water when using the cutter. It absorbs the vibrations and reduce the risk of breaking it.
17Back to top Go down   Mirror Repair Empty Re: Mirror Repair Tue Mar 08, 2011 7:42 pm
Brickee
Brickee
Thanks Bert, next time Gert decides to take a nap on a mirror it might be worth a try.
Martin
18Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Mar 09, 2011 11:27 am
Oldgoat
Oldgoat
Great tip and excellent timing as I've got a bathroom project coming up this weekend and this will be invaluable. Laughing
19Back to top Go down   Mirror Repair Empty Re: Mirror Repair Wed Mar 09, 2011 11:59 am
Yes this is invaluable for bathroom projects too. If you have to drill a ceramic tile, this is the way to do it. You can also lay your tile on a piece of soft rubber.
20Back to top Go down   Mirror Repair Empty Re: Mirror Repair Sat Mar 12, 2011 9:33 am
chrish8846
I too ended up buying OEM, mine came with a clip on the back to hold the mirror to the case, you have to take the mirror apart to install the clip. Mine also had 4 layers of paint and was a bugger to get apart.
Chris Hammond
1985 K100 RT sold
