1Back to top Go down   Pilot bearing bush pushed back Empty Pilot bearing bush pushed back Wed Dec 11, 2024 4:43 pm
Jtoregan
Jtoregan
I am reinstalling the clutch with the Clymer manual, and had to use a 3 armed puller to remove it, and pushed the pilot bearing bush in by about 5 mm. I found this post about it https://www.k100-forum.com/t15657-solvedmoved-pilot-bearing-bush but the answers seemed to vary from its OK as long as it's not too far back, to tapping it and replacing it. Can you tell me which is the best solution?
Pilot bearing bush pushed back 20241211
'86 K100
2Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Wed Dec 11, 2024 4:45 pm
Jtoregan
Jtoregan
One of the responses suggested using a harbor freight Bush puller, but the link was dead. Looks like this is similar?
https://www.harborfreight.com/two-jaw-pilot-bearing-puller-58209.html
'86 K100
3Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Wed Dec 11, 2024 7:24 pm
At the bottom of the thread will be a very hard O-ring which needs to be removed before attempting to remove the clutch basket. It will not come out easily and needs to be dismembered using a sharpened screwdriver to cut it up into a few pieces. After that has been removed the basket will slide of easily, if you use a puller all that will happen is at best a distortion of the basket and worst breaking it.
4Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Wed Dec 11, 2024 8:42 pm
Jtoregan
Jtoregan
I was able to get it out with the puller per the clymer manual, but when I was putting it back in I noticed the bushing was recessed. It was flush before, here's a before pic:Pilot bearing bush pushed back 20241110
'86 K100
5Back to top Go down   Pilot bearing bush pushed back Empty Pilot bearing bush Wed Dec 11, 2024 10:30 pm
daveyson
daveyson
A couple of options. You can get special pullers for that with an L shaped end that fits behind the bush, which will pull it back out without causing damage. You could get a suitable bolt and cut half the head off, creating a similar L shape, put it, in fill the hole with something, then pull it out, but then you would want to replace the bush. Or do a similar thing with a heel bar.
 ~120,000 km
6Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Thu Dec 12, 2024 12:02 pm
Jtoregan
Jtoregan
daveyson wrote:A couple of options. You can get special pullers for that with an L shaped end that fits behind the bush, which will pull it back out without causing damage.
Is this the tool you are referring to?
'86 K100
7Back to top Go down   Pilot bearing bush pushed back Empty Pilot bearing Thu Dec 12, 2024 3:34 pm
daveyson
daveyson
No, it says half an inch, that's too big.
I'm thinking something like this:
https://www.aliexpress.com/
Not sure if 6 mm is ok, you need to measure it.
Sorry that Link didn't work, I'll try again later.
I can't get it. At AliExpress is a heavy duty bearing puller fixture 6 to 19 mm add. It's $5.52. it has a short video for how to use it. It's for use with a slide hammer.
Hopefully someone else will attach it to a post.
 ~120,000 km
8Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Thu Dec 12, 2024 3:58 pm
The bushing should be 6mmX12mmX12mm. If you intend to reset it flush, you'll need a blind hole bearing extractor—otherwise known as a puller. The extractor will need a collet or jaws that will fit into that 6mm hole. The set in the photo below has a 5.8mm collet that would work. You can use either the supplied slide hammer or the supplied counterstay. Call NAPA, Pep Boys, AutoZone, etc. Some times they lend such tools at no cost if you leave a security deposit using a credit card and return the tool undamaged.
Pilot bearing bush pushed back Scree346
Let Chuckles show you how in the video below. You could use the slide hammer to knock it upwards to be more satisfactory for you.
9Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Thu Dec 12, 2024 4:20 pm
Here's a set at AliExpress that has a 5.8mm collet. Its price has been marked down 2%! Smile
 Pilot bearing bush pushed back Scree347
10Back to top Go down   Pilot bearing bush pushed back Empty Blind Bearing Tool advisory Fri Dec 13, 2024 5:36 am
redrockmania
redrockmania
These are great tools but be careful when operating. Do NOT steady the tool with your left hand on the shaft below the upper end handle. Why? When sliding the moveable weight upwards using your right hand with considerable force to hit the end handle, if your hand is in the way, you will injure it. Easy to do when focussed on getting a bearing out.Keep you left hand completely on the upper handle
11Back to top Go down   Pilot bearing bush pushed back Empty Pilot bearing bush Sun Dec 15, 2024 2:41 am
daveyson
daveyson
True, be careful.
Sometimes when it's unusually difficult you can resort to a special tool. Dunno the American term for it, it's an attitude adjustment tool, and it looks like this:
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRsLOGwMEu0WCalGYndB1peKwXx7nLeEY0Vq6TWfVaaD3zXjqxKImCKxUQ&s=10
 ~120,000 km
12Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Tue Dec 17, 2024 10:10 am
Jordan53
Jordan53
I haven't done this job on a K100, but I discovered a way to remove a bush from a blind hole.
Method is to cut up some solder wire into small pieces and fill the cavity with them through the bush. Pieces of lead should work too.
Then use a steel rod which is a sliding fit in the bush, and tap with a hammer, whereupon the bush will be pushed out from behind.
Some people use bread or grease instead of solder.
I did this to remove a split roll pin that had broken flush with the surface of a blind hole.
1989 K100 RS
VIN: xxx0149621
13Back to top Go down   Pilot bearing bush pushed back Empty Re: Pilot bearing bush pushed back Tue Dec 17, 2024 10:12 am
Jordan53
Jordan53
daveyson wrote:Sometimes when it's unusually difficult you can resort to a special tool. Dunno the American term for it, it's an attitude adjustment tool, and it looks like this:
The part number for this tool is No.1
1989 K100 RS
VIN: xxx0149621
14Back to top Go down   Pilot bearing bush pushed back Empty Blind hole? Wed Dec 18, 2024 5:58 pm
Gopher Baroque
Gopher Baroque
Is the bush in a blind hole?
My first thought was the classic tip to fill the hole with grease, then tap in a close-fitting drift to push the bushing out with pressurized grease behind.
I was impressed how slick this worked the first time I needed to try it.
