1Back to top Go down   Front Wheel Removal. How? Empty Front Wheel Removal. How? Tue Dec 24, 2024 10:12 am
Marketiello
Marketiello
How come to remove the front wheel of my 1986 K100 RS I have to remove the brake calipers and to remove the brake calipers I also have to loosen the brake discs?!? In other words, is it not possible to simply remove the front wheel without dismantling all this stuff? The wheel is prevented from being removed by the brake calipers but in turn the brake calipers cannot be removed because - once freed - they hit the rim so the brake discs must also be loosened!!! My God, this is ABSURD!  Surprised
Where am I going wrong?
2Back to top Go down   Front Wheel Removal. How? Empty Re: Front Wheel Removal. How? Tue Dec 24, 2024 11:31 am
You should be able to get the calipers off without loosening the brake discs.
3Back to top Go down   Front Wheel Removal. How? Empty Re: Front Wheel Removal. How? Tue Dec 24, 2024 1:19 pm
Make sure the pads are loose in the calipers. Wriggle the calipers to push the pistons in before trying to remove the calipers. As Duck says, the calipers will come off without removing the discs.
You won't have permission to post pictures directly into the forum yet (not enough posts), but you could try posting a picture of your problem to somewhere like ImgBB and giving us a link to it.
4Back to top Go down   Front Wheel Removal. How? Empty Re: Front Wheel Removal. How? Tue Dec 24, 2024 1:21 pm
I'm moving this from Troubleshooting - How To Tell Others How To Do a Specific Job... to Troubleshooting - Frame, Fairing, Wheels...because you're asking, not telling, and clearly unsure of a basic task. Good to ask before diving in and going over your head. I've also edited the heading down from ALL CAPS to a more normal size because, well,  even when we've had our frust-ration, there's no need to shout.  Smile
Remove the calliper mounting bolts, slide the callipers backwards off the discs a small amount, then twist the calliper bodies slightly to press the hydraulic pistons back in a smidgen. The callipers will then slide off between the discs and the wheel rim because you've now created enough room. Nearly all bikes are like this.
The forest was shrinking, but the trees kept voting for the axe, for the axe was clever, and convinced the trees that because his handle was made of wood, he was one of them. -Turkish proverb
5Back to top Go down   Front Wheel Removal. How? Empty Re: Front Wheel Removal. How? Tue Dec 24, 2024 2:38 pm
Alternative method is to 1/ Remove the plastic caliper pad covers. 2/ Remove the pad retaining pins. 3/ Slide the pads out and mark the location and orientation of the pads. 4/ Unbolt and remove the calipers.
Regards Martin. santa rendeer
6Back to top Go down   Front Wheel Removal. How? Empty Re: Front Wheel Removal. How? Wed Dec 25, 2024 2:51 am
Are the original calipers fitted on your K100? You don't need to remove discs to remove the front wheel. Even on K100RS1 with a 17 inch wheel and 305mm discs it's OK, so on a standard K100 with small disc and a big rim it's not an issue.
Photos would help...
That fills our fairest day.
