1 K1100LT - 1993 not starting - starting - not starting Fri Jan 03, 2025 10:44 am
ewout
My K1100LT has run perfectly fine all year. However, during the fall, it started to become slightly less eager to start, though it wasn’t really an issue. That is, until it suddenly wouldn’t start anymore. When I turn the ignition on, I can hear the fuel pump running, and I hear the return fuel trickling back into the tank. The starter motor turns over, and sometimes it seems like it’s about to catch, but in the end, it doesn’t start.
It’s worth mentioning that the motorcycle is stored outside.
Checked:
After reconnecting the fuel line to the rail, I tried starting it again, and suddenly, it ran! I let it idle for about a minute, turned it off, and tried again, but nothing—absolutely nothing.
I disconnected and reconnected the fuel line again, but it still won’t start...
What now? The ignition seems fine, the fuel pump appears to be working, but something seems wrong with the fuel delivery.
Has anyone experienced something like this before?
I have already found this great guide, which I will go through in detail: https://www.kforum-tech.com/forum-area/__Files/electrical/EFI/bike-wont-start-EN.htm . Based on this I am suspecting the various sensors that affect the Fuel Injection system. So next task will be to disconnect and reconnect all elements of the FI system.
Checked:
- Electrical connections (all look good). I disconnected and reconnected the injector plugs (haven’t measured resistance yet), and the spark plugs look fine.
- All spark plugs are sparking (I can’t check the timing).
- Water in the tank? No unusual signs around the fuel cap. I disconnected the fuel line at the injector rail, and there was no water in the fuel. When I turn the ignition on (without starting), about 50 ml of fuel comes out of the line each time with a strong stream. I haven’t tested how much fuel comes out during starting.
