1Back to top Go down   Alternator 2 pin plug Empty Alternator 2 pin plug Mon Jan 06, 2025 7:59 pm
naut023
naut023
I need to replace the 2 pin plug that goes in the back of the alternator. Looks like it is considered part of the harness so I can't find a part number for it.
Does anyone know if there is a part number or an off the shelf connector that fits well?
1985 K100RS
2Back to top Go down   Alternator 2 pin plug Empty Re: Alternator 2 pin plug Tue Jan 07, 2025 8:12 am
Depending on the problem you have, there's two solutions.
- If the plug is okay but the terminals are corroded, check the front of the plug. There should be a small recess next to each terminal; slide a thin piece of steel in there and give it a good wiggle to depress the terminal latch. The terminals should just pull out after that. Replacements are easy to find but be certain you buy the ones with a latch on them
- If the connector housing is damaged, crimp on two separate non-latch terminals complete with the insulated covers.
Both types should be easily available at an electronics shop or on Ebay/AliExpress.
If the red cable to the alternator is badly corroded to the point where you can't strip it back to good clean copper before crimping on new terminals, cut it right back to where it enters the wiring loom and insulate it properly with self-amalgamating tape. It forms a Y-joint at this point which goes to the battery, so you will need to make a new red cable that goes directly from the battery to the alternator. You'll then have two connections on the battery.
I've employed all the above fixes/bodges at some time or another and not had any problems.
3Back to top Go down   Alternator 2 pin plug Empty Re: Alternator 2 pin plug Tue Jan 07, 2025 6:14 pm
naut023
naut023
Perfect, thanks Dai.
I will try 1 but suspect the plug is too far gone. But 2 is an easy alternative.
1985 K100RS
4Back to top Go down   Alternator 2 pin plug Empty Re: Alternator 2 pin plug Wed Jan 08, 2025 1:14 pm
Visit an auto-electrician repair shop where starters and alternators are rebuilt. This connector is quite common throughout Bosch's early line of alternators. There might just be a known good spare lying about.
The forest was shrinking, but the trees kept voting for the axe, for the axe was clever, and convinced the trees that because his handle was made of wood, he was one of them. -Turkish proverb
