1Back to top Go down   failure to idle on BMW K100 Empty failure to idle on BMW K100 Tue Jan 07, 2025 3:16 pm
letsgetpractical
letsgetpractical
I have a problem with my K100 that has progressively gotten worse.  It will not idle when the bike is warmed up.  Yet when I cold start initially it does idle although it will stall out eventually.  When warmed up it will not idle at all and I have turned idle adjustment up to maximum.  I checked for air leaks using propane and did not discover any although I dont know if this is the best way to check.  I balanced the throttle bodies and no improvement.  Its there something in the FI system that could cause this?
I own a 1985 KRT 100 Bmw
2Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Tue Jan 07, 2025 3:47 pm
This is the same problem that you described in this post, correct?
3Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Tue Jan 07, 2025 6:33 pm
Sounds like you might have a bad engine coolant sensor.  Fairly common problem on these old beasts.  Makes the engine run too rich when it's warmed up.
Should be around 250 ohms between pins 10 and 13 on the big connector on the Jetronic control unit when the engine is at operating temperature.
The cause can be a bad sensor or a dirty/corroded connection.
4Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 3:00 am
letsgetpractical
letsgetpractical
Laitch wrote:This is the same problem that you described in this post, correct?
Not exactly. That is another weird problem with this bike.  It will cold start ok, then conk out in 20-30 seconds and wont start.  I have found that if I start it, run till it conks out, don't try to start until at least a few minutes, it will fire up and idle again, probably conk out again with out being able to start.  Again I leave alone for a few minutes and usually after that it will run continually with no problem.  It is about a 10 minute ritual I go through with it.
But the idling problem is a completely different issue.  see my next post
5Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 3:03 am
letsgetpractical
letsgetpractical
Point-Seven-five wrote:Sounds like you might have a bad engine coolant sensor.  Fairly common problem on these old beasts.  Makes the engine run too rich when it's warmed up.
I have already replaced the engine coolant sensor with an OEM part.  no change.  And the issue is quite nuanced.  It will idle fine when I finally get it warmed up, but when I drive it, whenever I come up to a stop, it will stall if I dont give it some throttle.  Now, when the bike is warmed up and I start it, it will idle perfectly for ever if I let it.  So I dont think it's an air leak since it will idle fine under certain conditions.
6Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 5:41 am
Check the valve clearances, tight exhaust valves will cause that very problem.
7Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 9:49 am
If you have not replaced the fuel filter and and also replaced the internal tank fuel lines with J30R10 or equivalent submersible fuel injection lines, now might be the time to do it. A clogged filter and/or internally collapsing fuel lines can block sufficient fuel to keep the engine running. Fuel lines leaking from their clamped joints with pipes in the tank can also interfere with performance.
Blowing air through a clogged filter will be difficult so that is a test you can try.
8Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 10:45 am
Coils going bad can cause a bike to idle poorly once warmed up.
See page 15 here: Crazy Frog Troubleshooting
9Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 3:59 pm
letsgetpractical
letsgetpractical
Laitch wrote:If you have not replaced the fuel filter and and also replaced the internal tank fuel lines with J30R10 or equivalent submersible fuel injection lines, now might be the time to do it. A clogged filter and/or internally collapsing fuel lines can block sufficient fuel to keep the engine running. Fuel lines leaking from their clamped joints with pipes in the tank can also interfere with performance.
fuel filter replaced, it runs great on highway at full speed
10Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 4:11 pm
letsgetpractical
letsgetpractical
because it conks out as I approach a stop light but idles fine if I turn off and then start again, I think it is a problem with the fuel delivery.  Doesn't this bike have a feature where the fuel supply is cut off totally when you close the throttle and are slowing down?  I am thinking there is something wrong with the system or sensors that guide this system but not sure how to diagnose it
11Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 7:41 pm
1985... is this an 8-valve or a 16-valve engine? '85 was a changeover year so saying a bike is a 1985 K100RT can be misleading. Also, it may not have started life as an RT (mine didn't). Reason for asking: if it's an 8-valve engine then you could be on to something. If it is 8-valve, look for a purple/white wire (probably look more like shitty purple/light brown) at the rear of the throttle bodies and pull it off the vacuum switch. BMW deprecated the vacuum switch because it caused idling problems - I'm not sure when, so you may not have one. If that's not the problem just tie the wire back - don't bother reconnecting it to the vacuum switch.
Both engines: if you're thinking of the TPS (throttle position switch), that's on the r/h side of the throttle body bank. Loosen the two screws just enough so that you can rotate the TPS housing. You'll need a quiet environment. Rotate the switch away from you (clockwise) very slowly and gently. You're listening for a tiny, almost inaudible click as a microswitch engages. If you don't hear it within about ten degrees of rotation, rotate back towards you (anti-clockwise). When you hear the click, rotate clockwise a tiny amount (you may even hear another click). What you have just done is to effectively turn the TPS sensor off, so it will be removed from the problem-solving process. Downside; if you've gotten used to the ignition system switching off and using the engine for braking when slowing down, it's now going to behave like any non-BMW bike and the engine braking won't be anywhere near as much. You get used to it. Upside: it makes cornering and roundabouts much easier because the ignition system isn't switching on and off with the throttle being opened and closed.
12Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 7:58 pm
The reason I point to coils is that a local guy with an 85 K100 was having an issue where his bike idled very poorly once it warmed up. He came by my place, we swapped in another set of coils and the problem went away.
13Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Wed Jan 08, 2025 8:30 pm
daveyson
daveyson
letsgetpractical wrote:It will not idle when the bike is warmed up.
This is a good time to do some tests, when it's not working. At this point check to see if the spark plugs are wet or dry. But before that, with the help of a screwdriver, I'd check to see if the injectors stop ticking before your brick stalls. With the help of a timing gun, check to see if the spark plugs are getting current from the spark plug leads.
I'm thinking you might have two separate problems, a starting problem, and a stalling at intersections problem. I'm going to suggest two unlikely solutions, but worth mentioning cause they are simple quick things to try. Your starting problem reminds me of one I had. Swapping the fuel injection computer might be the solution, or brush and clean it's multi plug connections with Deoxit, let it dry, then plug it back in. Cleaning it is a good thing to do, even if it doesn't solve the problem, and maybe clean the ignition computer plug and other plugs while at it. The stalling at intersections problem reminds me of a forum member with that problem. The solution in that case was replacing worn brushes in the alternator. I wouldn't be able to find that thread back again. If swapping the alternator solves the stalling at intersections problem, that's a pretty good clue.
I think we're sposing that the battery is good.
 ~120,000 km
14Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Thu Jan 09, 2025 11:44 am
I had a similar problem with a 16 valve 1992 K100RS.
After running at cruising speed for 10 or more miles the engine would quit when coming to a stop.  (Think running a distance on the interstate and then having the engine die when coming to a stop at the end of an exit ramp.)  The engine would immediately restart and then run okay.
I still have no idea what the actual cause of the stall was, but I seem to recall that installing new spark plugs during annual maintenance fixed the problem.  On your bike you might want to take Duck's advice and check the coils.  If you can't remember when the spark plugs were replaced, that might be something else to look at.
15Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Thu Jan 09, 2025 2:11 pm
letsgetpractical
letsgetpractical
Dai wrote:1985... is this an 8-valve or a 16-valve engine? '85 was a changeover year so saying a bike is a 1985 K100RT can be misleading. Also, it may not have started life as an RT (mine didn't). Reason for asking: if it's an 8-valve engine then you could be on to something. If it is 8-valve, look for a purple/white wire (probably look more like shitty purple/light brown) at the rear of the throttle bodies and pull it off the vacuum switch. BMW deprecated the vacuum switch because it caused idling problems - I'm not sure when, so you may not have one. If that's not the problem just tie the wire back - don't bother reconnecting it to the vacuum switch.
I am going to look into this, thanks.  I didnt fully describe everything I have tried already which didnt work.  I have a spare K100, same year.  I switched the coils, switched the ecu unit, changed the spark plugs, changed fuel filter, cleaned all wire connectors I could find, still no change.
16Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Thu Jan 09, 2025 2:54 pm
daveyson
daveyson
I'm also liking Ducks suggestions. It sounds like both your bricks are early models, you're possibly thinking surely I haven't got four bad coils, I'm thinking, yep, could be. I've got an '84 brick, these early models are known for having bad coils. It won't start when cold, when warm it will start pronto, and I'll ride it around the block, no problemo. I tested them as in Bert's guide that Duck has given a link to, and guess what, they're both open circuit! I guess they have a crack somewhere. Cracks are a funny thing, they can get bigger when they get warm, or they can close up when they get warm, or both, or the opposite, I guess, depending on where the crack is.
Swapping the computers might not help if the multi plug isn't squeaky clean.
Another thing you could try would be to install a fuel pressure gauge and watch if the fuel pressure drops (or rises) before your brick stalls.
 ~120,000 km
17Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Thu Jan 09, 2025 3:45 pm
letsgetpractical
letsgetpractical
Both engines: if you're thinking of the TPS (throttle position switch), that's on the r/h side of the throttle body bank. Loosen the two screws just enough so that you can rotate the TPS housing. You'll need a quiet environment. Rotate the switch away from you (clockwise) very slowly and gently. You're listening for a tiny, almost inaudible click as a microswitch engages. If you don't hear it within about ten degrees of rotation, rotate back towards you (anti-clockwise). When you hear the click, rotate clockwise a tiny amount (you may even hear another click). What you have just done is to effectively turn the TPS sensor off, so it will be removed from the problem-solving process. Downside; if you've gotten used to the ignition system switching off and using the engine for braking when slowing down, it's now going to behave like any non-BMW bike and the engine braking won't be anywhere near as much. You get used to it. Upside: it makes cornering and roundabouts much easier because the ignition system isn't switching on and off with the throttle being opened and closed.  I looked for the vacuum switch wire and switch and didnt see any.  Is that visible without removing anything?  I believe I have an 8 valve bike but it was sold in Germany and brought over by a US soldier there at the time, so it may be configured differently and not have the vacuum switch?  I rotated the TPS until i heard a click like you said and then tightened it down.  Didnt make any difference.....
18Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Fri Jan 10, 2025 7:23 am
Post a pic of the l/h side of the engine. We're flying in the dark ATM.
19Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Fri Jan 10, 2025 8:12 am
I'm not clear why there's confusion about it being an 8 valve. If it's 1983 thru 1989 (thereabouts) it's an 8 valve.16 valve engines with Motronic are K1 or K100RS ABS, later on K1100RS.
Post the last seven digits of the bike's VIN and we'll know what it was meant to be in a flash.
Also, if you reply to someone's advice and use quote, please write outside the box. Otherwise it's hunting and pecking between what was written, and your responses.
The forest was shrinking, but the trees kept voting for the axe, for the axe was clever, and convinced the trees that because his handle was made of wood, he was one of them. -Turkish proverb
20Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Fri Jan 10, 2025 2:25 pm
letsgetpractical
letsgetpractical
Dai wrote:Post a pic of the l/h side of the engine. We're flying in the dark ATM.
failure to idle on BMW K100 20250110
21Back to top Go down   failure to idle on BMW K100 Empty Failure to idle Fri Jan 10, 2025 2:47 pm
daveyson
daveyson
Yep, you have the earlier '85 model.
See the vacuum hose from throttle body four, it looks too new to be the original one, good. It goes to the fuel pressure regulator. Originally it had an external coil to prevent it from collapsing when under vacuum. It looks to be partially kinked, I think, but I'm not too sure about this. That might get worse when the hose gets warm, with the result of over fuelling when the engine is warm.
Maybe that's why your brick stalls when it gets warm. Too much fuel wouldn't be so critical when the engine is cold.
 ~120,000 km
22Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Fri Jan 10, 2025 8:37 pm
Check also if you have a vacuum pipe off no 1, in addition to the vacuum cap. 3 of my Ks have a vacuum sensor located beside the fuel pressure regulator, with a vacuum pipe from no 1 throttle body which also has a vacuum cap. You can replace this pipe with a vacuum cap. Your cam cover suggests you might have one.
1996 K1100LT 0233004 Lohengrin Mystic Red 38,000 miles currently 54,800 miles.
1983 K100RS 0004449 Odette R100 colours 58,000 miles. Sprint fairing now 64,500 miles
23Back to top Go down   failure to idle on BMW K100 Empty Failure to idle Sat Jan 11, 2025 1:39 am
daveyson
daveyson
Because yours is an early '85 model, it should have the vacuum switch, which gets vacuum, as Olaf states, from throttle body one. I'm thinking a vacuum leak here would be less catastrophic than a normal vacuum leak, for example from the fuel pressure regulator. I'm only thinking that because I assume the vacuum switch serves the same purpose as the vacuum timing advance in the carby days. Remember in the carby days the distributor had a mechanical advance and a vacuum advance. The timing was advanced under vacuum to allow for low load situations which mainly come into play at mid throttle ranges, so shouldn't have an impact at idle, unless of course the hose is split or has slipped off its port. Remember this port was typically above the throttle valve, so the vacuum at this point is lower than usual.
The hose is connected to the left of the vacuum plug at throttle body one. The vacuum switch itself you can see from the right side of your brick, between the radiator and the air filter box.
Hopefully your hose isn't kinked and split like mine is.
failure to idle on BMW K100 Img_2126
failure to idle on BMW K100 Img_2128
 ~120,000 km
24Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sat Jan 11, 2025 4:12 pm
letsgetpractical
letsgetpractical
daveyson wrote:Because yours is an early '85 model, it should have the vacuum switch, which gets vacuum, as Olaf states, from throttle body one. I'm thinking a vacuum leak here would be less catastrophic than a normal vacuum leak, for example from the fuel pressure regulator. I'm only thinking that because I assume the vacuum switch serves the same purpose as the vacuum timing advance in the carby days. Remember in the carby days the distributor had a mechanical advance and a vacuum advance. The timing was advanced under vacuum to allow for low load situations which mainly come into play at mid throttle ranges, so shouldn't have an impact at idle, unless of course the hose is split or has slipped off its port. Remember this port was typically above the throttle valve, so the vacuum at this point is lower than usual.
thanks, I will check that out!
25Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sat Jan 11, 2025 5:53 pm
As said, it will run fine without it. All I was suggesting is disconnect the hose at the throttle body and put a vacuum cap on instead, that way your vacuum is unaffected. I admit on 2 of my Ks I have kept that vacuum switch connected and doing its thing but they work fine without it.
26Back to top Go down   failure to idle on BMW K100 Empty Failure to idle Sat Jan 11, 2025 6:09 pm
daveyson
daveyson
Good idea, a very quick way to eliminate it as a cause of the problem.
I was mainly just aiming to answer the question as to where the switch is.
Sometimes I think I should test this one day, which I did once with a test light, but I should do a better test to see if it really does advance the timing. I'm pretty sure it will, even with the split in the hose, since I think I remember that the switch did send a signal to the ignition control unit when held at mid rev ranges, but not at idle. I did post the results somewhere but couldn't find it back.
 ~120,000 km
27Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sat Jan 11, 2025 10:51 pm
daveyson wrote:Good idea, a very quick way to eliminate it as a cause of the problem.
I have kept mine connected because my 83 RS has the engineering screws etc as well and it feels so much quicker. It started out as an RS and I really got to like it. Getting treated to a new clutch and rear main seal etc in the next few months.
28Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 3:50 pm
letsgetpractical
letsgetpractical
I have looked on my bike and do not see a hose on the left side of the throttle body, which is I assume is where throttle body one is.  When I looked for vacuum switch I saw 2 cut wires, one purple like color which is the wire for the vacuum switch?  Also on throttle body one there is just one capped vacuum port, is there to be another port somewhere for this vacuum switch?
29Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 3:52 pm
letsgetpractical
letsgetpractical
Also on the right side of the throttle bodies there is a vacuum hose going out of a nipple on the farthest right throttle body.   Would that be the vacuum hose going to the vacuum switch, if not, where does that go?
30Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 4:44 pm
letsgetpractical wrote:Also on the right side of the throttle bodies there is a vacuum hose going out of a nipple on the farthest right throttle body.   Would that be the vacuum hose going to the vacuum switch, if not, where does that go?
No. The hose on throttle body #4 is connected to the fuel pressure regulator. If your Brick had a vacuum switch, it would be connected to the port on throttle body #1. BMW discontinued the vacuum switch in April 1985, because it didn't seem to have much effect on most Bricks.
From the K75-K100 2-valve shop manual downloadable from this site's Tech Page:
failure to idle on BMW K100 Scree355
31Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 6:39 pm
If you have the vacuum switch, or had it, there are 2 vacuum points on no 1 throttle body.
1-4 have them in identical positions, on no 4 it goes to the fuel pressure regulator using a pipe instead of having a cap. 1-3 should have vacuum caps. On no 1 the second one was a pipe which went to the vacuum sensor. This vacuum pipe is very prone to cracking and will cause you problems so just use a vacuum cap instead.
32Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 9:52 pm
letsgetpractical
letsgetpractical
92KK 84WW Olaf wrote:If you have the vacuum switch, or had it, there are 2 vacuum points on no 1 throttle body.
yes I see where you mean.  The outlet has been capped and I guess the vacuum switch you speak of has been disconnected long ago by the prior owner.  I have owned this bike for over 10 years.  Never had any problems with it until about 2 years ago.
33Back to top Go down   failure to idle on BMW K100 Empty Failure to idle Sun Jan 12, 2025 10:03 pm
daveyson
daveyson
The vacuum hose at throttle body four, remove it from the throttle body and look inside it, it should be dry, if it's damp, that's a problem. If it's dry, replace it, run the bike for a minute, then stop it. Again look inside the hose, again, it should be dry.
How many vacuum caps are there on throttle body one?
 ~120,000 km
34Back to top Go down   failure to idle on BMW K100 Empty Re: failure to idle on BMW K100 Sun Jan 12, 2025 10:17 pm
letsgetpractical
letsgetpractical
Is there any way to completely shut off the fuel shut off system when decelerating?  I think my problem lies in that system when my bike cuts out when I stop at stop light.  I think the shut off of fuel is still happening when I completely stop.  I tried rotating TPS slightly as suggested but didnt change any thing.  Can I rotate that switch in a certain direction for a good amount that would guarantee the shut off of fuel would not occur any more or is there some other way of disconnecting that system?
35Back to top Go down   failure to idle on BMW K100 Empty Failure to idle Sun Jan 12, 2025 10:28 pm
daveyson
daveyson
Yes the fuel shuts off on deceleration, but it turns on again when the revs drop below 2,000 rpm. I don't think that would be your problem.
We don't know yet if it's a fuel problem or an electrical problem. Probably best to find that out first.
When it conks out, are the spark plugs wet or dry?
 ~120,000 km
