1Back to top Go down   Parameter pivot bearings Empty Parameter pivot bearings Wed Jan 08, 2025 7:17 pm
pjntc
pjntc
Parameter pivot bearings Img_0210Parameter pivot bearings Img_02101990 K1 installing swingarm, one of these goes on the left front of the swingarm one goes on the rear right side connecting the final drive. One is steel the other is aluminum. They are the same length but the steel one has just a few less threads. Which one goes where ?
84 K100rs
74 Yamaha RD350
2018 Triumph Bonneville
1990 K1
2Back to top Go down   Parameter pivot bearings Empty Re: Parameter pivot bearings Wed Jan 08, 2025 7:29 pm
Left one is final drive
Right one is swing arm
3Back to top Go down   Parameter pivot bearings Empty Re: Parameter pivot bearings Thu Jan 09, 2025 7:39 pm
Do you mean Paralever? I've not heard of Parameter related to Beemer swingarm or final drive pivots.
The forest was shrinking, but the trees kept voting for the axe, for the axe was clever, and convinced the trees that because his handle was made of wood, he was one of them. -Turkish proverb
4Back to top Go down   Parameter pivot bearings Empty Re: Parameter pivot bearings Fri Jan 10, 2025 5:03 am
pjntc
pjntc
Paralever parameter
84 K100rs
74 Yamaha RD350
1990 K1
5Back to top Go down   Parameter pivot bearings Empty Re: Parameter pivot bearings Fri Jan 10, 2025 7:22 am
Potato, potato, tomato, tomato...
(Okay, okay. The door's that way).
6Back to top Go down   Parameter pivot bearings Empty Re: Parameter pivot bearings Sat Jan 11, 2025 10:59 am
pjntc wrote:Paralever parameter
Paramount, paradise, paragraph, paramour, parachute, parable & parabola. It's practically a paradigm.
