Draining the final drive Yesterday at 7:05 pm
jjefferies
![jjefferies](https://2img.net/u/4211/29/48/93/avatars/2834-53.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
Ok, so I've got this 1990 K75S that I'm resurrecting. Several threads about the electrics elsewhere. But the other day along with my other projects God or his angels made me question if the tranny and final drive were properly lubed. I had just turned it on and wondered if all the driveshaft was properly lubed. So I checked. Tranny looked Ok, but when I opened the final drive/rear end I was gob smacked to see the color of the lube was orange and bubbly. Looked like water to me. How the rear end got water in it is beyond me or this thread. But there it was. So I went down to the shop and bought a quart of 80/90 lube.
Now Here is where I would appreciate your criticism and suggestions. How to get the bad fluid out. I opened the final drive and let it drain. Definitely water. But being a worrier I wondered if that was sufficient. So I got a spray can of WD-40. Don't know if it is known by that name outside of the US. But I closed the bottom drain hole and sprayed most of the can into the final drive. Then I turned the bike on and with it on the center stand I spun up the rear wheel. Then I drained the WD-40 into a separate container and looked at it. Didn't look particularly bad but I'm still letting it drain for an hour or so.
My question, in your opinion is that sufficient to clear any lingering water out of the system? So that I can refill the final drive.
thanks for the attention
J.
J.
