1Back to top Go down   Case Rivet Size... Empty Case Rivet Size... Tue Aug 30, 2011 11:35 am
twincarb
twincarb
Afternoon all,
Does anyone know what the correct size rivets that are used to hold the latches on the side luggage are? from my collection i seem not to have any that are the right size, so need to order some. The fishe's i have looked at don't appear to show the size!
2Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Tue Aug 30, 2011 3:05 pm
3.2mm or in the old scale 1/8 th but you will find different lengths are required ... about 10-12 mm twincarb
hope this helps
3Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Tue Aug 30, 2011 8:58 pm
Use stainless ones as the aluminium ones will corode. It is what causes most of the panniers to commit suiside on freeways in front of trucks.
4Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Wed Aug 31, 2011 12:17 am
Unless of course the owner is smart enough to make straps to go around. I have of course used aluminium ones, so don't ride behind me.
5Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Wed Aug 31, 2011 4:50 am
twincarb
twincarb
excellent,
I just need to pop to my local screw shop and get some, I should have my case's all clean and back together this evening Very Happy
Yamaha Thundercat
Case Rivet Size... 169042Case Rivet Size... 169034
6Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Wed Aug 31, 2011 4:51 am
i recon if aluminum lasts 10 - 20 plus years i wont complain about them corroding and drilling them out and replacing them .......which i have done recently
7Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Wed Aug 31, 2011 4:53 am
twincarb
twincarb
I have to agree charlie that the do last i am tempted to get black ones so they just blend in with the plastic.....
Yamaha Thundercat
8Back to top Go down   Case Rivet Size... Empty Re: Case Rivet Size... Wed Aug 31, 2011 5:15 am
geordnz
geordnz
I replaced my loose rivets with stainless screws, nuts and washers. You can't see any of them from the outside anyway. This allowed me to adjust the fittings to get the tightest fit without having to force the thin alloy fittings. I have the flat locks. I never lock any of them as I have FOUR different keys!
