1Back to top Go down   Speed bleeders - comments please Empty Speed bleeders - comments please Sun May 01, 2011 7:24 am
Well? Yes? No?
2Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 01, 2011 8:37 am
They make the job easier when you're alone in the garage. I don't 'need' them on my K100RS but use them on other bikes.
3Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 01, 2011 9:19 am
BIG D
BIG D
Cool
I have used them before with some success so I will say YES.
BIG D
4Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 01, 2011 10:43 am
Some success? I have heard mixed reviews.
So BIG D, not what you thought they would be?
5Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 01, 2011 2:12 pm
BIG D
BIG D
Cool
There is always some machine or vehicle that turns out to be a pig and in such situations the old slow method has been the saviour of the day I have various systems in my garage from expensive air operated systems to cheap one way valves I have used them all, depends on the machine but as a rule I reach for the one way valve and bottle first.
BIG D
6Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Mon May 02, 2011 2:19 am
I only just finished bleeding the brakes on my K1100LT and the speed bleeders worked on the rear but were hpoeless on the front twin spots.
It has taken two days to do the front calipers and ABS and it is still not perfect.
7Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Mon May 02, 2011 2:57 am
Personally I have always preferred pressure bleeding on vehicles but that can be a problem when one cannot get the cap onto the reserve cylinder or if the cylinder is brittle as was discussed a few days ago.
I found that having put a good coat of thick silicone grease around the brake bleed valve to prevent air leaks looking like air coming out of the system, suction with a Mityvac on the bleed valve was excellent at getting all air out of the system.
8Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Mon May 02, 2011 4:26 am
BIG D
BIG D
Cool
Yes the Mityvac is a good kit K-bike.
BIG D
9Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Fri May 13, 2011 4:49 pm
IPJ100
IPJ100
After a recent refurb of my 84 RS rear brake master cylinder and caliper i could not get it to start taking fluid from the resovoir. A friend of mine offered to run back home and get his speed bleed kit but we tried something else first.
I managed to pour some fluid into the caliper in the reverse manner to which it should have come out from, effectively sucking it in the wrong way. after a good few pumps like this it started to draw from the resovoir and then bled the ol fashioned way - up / down / close / open.
pedal is firm and stayed so - so far.
Ian
I still haven't started restoring my C90. damm it Speed bleeders - comments please 652573
10Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sat May 14, 2011 8:49 am
chrish8846
I have used speed bleeders on several cars that i have owned and found that they work well most of the time. On my personal car a 71 Cutlass convertible they worked on the front discs but not on the rear disc conversion. I had to bleed the rears the old fashioned way , pump and hold, open the bleeder,close bleeder, release and pump again (with my wife helping).
Chris Hammond
1985 K100 RT sold
1992 K75RT still in Fixing mode
11Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 15, 2011 6:37 am
Rickmeister
Rickmeister
Recently flushed my front and rear fluids, using a sucking machine. Rode about 200Km, brakes felt great. Yesterday a big pool of brake fluid appeared on the garage floor, from the rear master cylinder. Coincidence? Murphies Law?
12Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 15, 2011 6:53 am
yep that would be murphy... ulrich
you know mrs murphy always thought mr murphy was an optimist...
hope you get those seals fixed ...
cheers mate
13Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Sun May 15, 2011 7:00 am
BIG D
BIG D
Cool
Sorry to hear that ulrich,your murphy's must be the same as our sod's law always happens when you dont wont it or need it.
BIG D
14Back to top Go down   Speed bleeders - comments please Empty Re: Speed bleeders - comments please Mon May 16, 2011 6:23 pm
IPJ100
IPJ100
yep, sounds right. good old sod's law- appears from nowhere, does his stuff and leaves you to sort it out just when ya dont need it.
good luck with the repair!
Ian
