1Back to top Go down   Reinstalling the fuel tank Empty Reinstalling the fuel tank Mon Jul 25, 2011 10:12 pm
chronostorm
Hey guys,
I'm currently trying to fix up my 1987 K100, but I'm having some trouble with the fuel tank. It was disconnected when I got the bike, and I was wondering what lines go where to reconnect the tank to the rest of the bike.
2Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 4:41 am
twincarb
twincarb
Did you remove the pipes from the engine which go to the tank? I found that they naturally hang go towards the correct outlet on the bike.
That being as looking at the tank from the side the left hand pipe go's to the left outlet and the right to the right outlet, the pipes that are at the rear closest to the seat should be above the plastic overflow type drain....
Yamaha Thundercat
Reinstalling the fuel tank 169042Reinstalling the fuel tank 169034
3Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 5:53 am
all you need to remember is
that the fuel rail input ...tank output pipe, goes more or less straight down and is the rearward port on the tank .
4Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 11:32 am
chronostorm
twincarb wrote:Did you remove the pipes from the engine which go to the tank? I found that they naturally hang go towards the correct outlet on the bike.
I see 3 pipes: One in the left front, and two in the right back.
The left front one is where fuel gets sent to the engine, right? Does this one plug into the more forward hole or the more back one on the left side?
The back right has one thick line and one thin one. The thick one goes to a valve of sorts. Which one goes where?
Thanks a lot!
5Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 10:35 pm
chronostorm
I looked at the bike today, and it seems there's a spot near the top of the engine that seems to have an opening for a fuel line on the left side of the bike. It seems like that might have to be connected to the fuel tank on the left side as one of the two, since I'm missing one as of right now.
6Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 10:39 pm
Is this a replacement tank or the original. There are two types.
7Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 10:42 pm
chronostorm
K Freak wrote:Is this a replacement tank or the original. There are two types.
I don't know Sad. Is there a way to check? Thanks
8Back to top Go down   Reinstalling the fuel tank Empty Re: Reinstalling the fuel tank Tue Jul 26, 2011 10:56 pm
The two types are pre and post 85 so I will presume yours is the original.
There should be 2 tubes comming out of the tank at the front left, the front one is the return line which is connected to the rubber tube that comes from the fuel pressure regulator which is behind the throttle bodies.It comes out between the radiator and the air box plannum chamber which is on top of the throttle bodies. The rear tube connects to the square fuel rail that feeds the injectors which is almost directly below the it.
There are 2 tubes on the right side about mid way point and these drain into a small rectangular shaped plastic catch tub that has a drain tube attaches to the bottom of it and goes to the rear near where the battery overflow tube is placed just to the rear of the swingarm pivot.
Hope this helps
PS The pre 85 tank had a non return valve on the front return line which was superceeded because it often caused a bad rattle and the post 85 has the return line going to the highest point of the tank to prevent return flow.
