1Back to top Go down   Intermittant speedo Empty Intermittant speedo Mon Aug 15, 2011 4:57 pm
Puccini
My speedo cuts out every now and then.
If I tap the speedo housing it starts working again.
I know I have to clean the connections to the speedo.
Whats the easiest way to remove the Speedo/Tach housing to get at the electrical connections?
Gerry
85 K110RT
2Back to top Go down   Intermittant speedo Empty Re: Intermittant speedo Mon Aug 15, 2011 5:04 pm
Also check the connector under the right battery cover, two pole, one yellow and one brown wire.
Another link in the weak chain.
3Back to top Go down   Intermittant speedo Empty Re: Intermittant speedo Mon Aug 15, 2011 8:54 pm
gerry there are 2 x 5mm screws holding the instrument cluster to the steering head. you should be able to get at them by turning the bar one way ,,,,then undoing the one that presents itself ....then go the other way
they attach to a bracket which rises verticaly to the base of the instruments, the screws mount from the front of the bike.
4Back to top Go down   Intermittant speedo Empty Re: Intermittant speedo Mon Aug 15, 2011 8:59 pm
Taking the screen off can also help seeing what to do and getting at the two 5mm allen head bolts.
