1Back to top Go down   shifting into 5th gear Empty shifting into 5th gear Tue Jan 03, 2012 5:39 pm
joem
joem
Hi all, i just wanted to ask if anyone has experanced difficulty when going from 4th to 5th. it has just started and i first noticed it when i seemed to find a neutral when going from 4th to 5th, it seemed to need a solid shift to get it to go streat in. it now seems to be getting harder to go streat into 5th. on the way homw i tried it several times but was on the back road so the reves wer low when i was doing it. it seemed to be stiff. any idears.
regards joe.
2Back to top Go down   shifting into 5th gear Empty Re: shifting into 5th gear Tue Jan 03, 2012 6:36 pm
bushyintas
bushyintas
Hi Joe
I sometimes find a false neutral between 4th & 5th but if I preload the gear leaver just before squeezing the clutch it slips in nicely.
try changing your gear oil, only takes a few minutes to do and a litre of sae90 gear oil will do both gear box and final drive.
Regards Bushy
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
3Back to top Go down   shifting into 5th gear Empty Re: shifting into 5th gear Tue Jan 03, 2012 7:55 pm
Yep, I get the false neutral as well...but only when I get lazy and don't preload the shifter like Bushy said.
Some people report improved shifting when using a synthetic gearbox oil. I have synthetic in mine, but I don't notice much of an improvement to the shifting of the gears.
4Back to top Go down   shifting into 5th gear Empty Re: shifting into 5th gear Tue Jan 03, 2012 9:45 pm
I used the Castrol Syntrax 75-90 oil and was amazed how smooth the shifting is since I did it.
5Back to top Go down   shifting into 5th gear Empty Re: shifting into 5th gear Wed Jan 04, 2012 5:45 pm
joem
joem
thanks all for the advice, i will see how it goes
regards joe
