Go to page : 1, 2  Next
1Back to top Go down   WATERPROOF MP3 FM RAIO Empty WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 12:23 am
col
col
while searching the internet the other day i came across a mp3 fm radio that is waterproof has anyone ever put one of these on their bike
1991 k100lt "the enterprise"
2Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 2:22 am
col
col
3Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 4:58 am
I would be checking whether the weather proofing is valid for the front of the radio etc. only. The wiring in the photo suggests that it must remain totally dry. That may limit your mounting possibilities. ( of the radio, that is ) The aerial seems to be an extra...no problem if you are using the mp3 most of the time.
4Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:07 am
col
col
thinking of mounting on the left side of the fairing and usb on right as per 2 white circles in photo can buy usb lead (data cable) with mounting socket for dash with rubber cap,all connections behind dash use the trusty old heat shrink, mount arail on front of fairing, can also get power usb cable with 3.5mm socket with rubber capso i can run a lead to helmet for speakers
5Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:14 am
col
col
try agian with photo
6Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:24 am
col
col
second try agian
7Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:32 am
col
col
i cant get photo to upload even after following cf guide
technically useless is the often used with me and computers so i go with description in fairing on k100 lt large flat area about 90mm diameter i think it is where bmw mount speakers
unit on left so can adjust on the go
usb on right
second usb in left pad just below box lid because there is already hole there
8Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:36 am
col
col
hope this works
WATERPROOF MP3 FM RAIO Dscn1115
9Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:36 am
CanberraDave
CanberraDave
I was thinking of putting one of these into one of my glove boxes and a UHF in the other.
http://www.gme.net.au/products/entertainment-systems/stereo-radio-marine/GR200
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
10Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:41 am
col
col
we have them in the machines at work and they are ok but no usb input
you will just have to open lid to make adjustments like change station or tun volume up or down
11Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:43 am
col
col
12Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 5:57 am
CanberraDave
CanberraDave
No USB but they do have a connection you can plug the ipod into. That way you can change songs etc or even watch a movie if you have the right ipod!!!!!!! Just need to weatherproof the ipod. Given they are IP55 waterproof I was looking at using the flush mount kit and installing in the lid of the glovebox. That way I can get at the controls. Not sure if this will work yet but will investigate further once I get the girl back on the road.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
13Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 7:14 am
Have ye seen this set up ??
youtube clip - mp3 player on K100RT
the player buttons would be a bit fiddly with gloves on.
Vis a vis that marine one Col, make sure it's not just the buttons that are waterproof. The ones that CanberraDave posted are designed for speedboats/ RIB's etc and have waterproof connections to the rear.
Also bear in mind that once you mention "marine" the markup % goes through the roof. Why not just get an LT radio pocket cover and put in a stereo that takes a usb or Aux input?
88KE
WATERPROOF MP3 FM RAIO Ir-log1188....May contain nuts!WATERPROOF MP3 FM RAIO Ir-log11
K75RTP - 1994
14Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Nov 29, 2011 4:07 pm
Canberra Dave, are you expecting a lot of rain down your way? The unit you showed has a marine band radio. From memory Canberra is inland a fair bit. Oh well I better see if Noah is busy later on today.
15Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 3:59 am
CanberraDave
CanberraDave
If you had of been here last night Ainsjac you would have agreed I need a marine radio. 50mm in 24 hours. The reason for the marine jobby is more for the waterproof action than anything else. My plan is to have the dials outside the lid of the glove box so I can adjust on the move.
Still investigating solutions though as things like that are a bit far off to worry about yet.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
16Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 4:57 am
col
col
have found distributer in china who makes the one iam looking at negoting price
18Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 6:22 am
bushyintas
bushyintas
sorry posted the same link twice, should have been a pic of my radio.
Here it is, I hope WATERPROOF MP3 FM RAIO 78846
WATERPROOF MP3 FM RAIO Radio11
Bushy
19Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 1:35 pm
Thats a very neat looking setup Bushyintas. I like some of the mods you've made, I'm particularly intrigued by the hoses on the side of the tank - I presume these are for cooling air in hot weather (which we don't realy get Sad ). Your screen looks interesting too. Any threads on the mods you've made?
88KE
Last edited by 88KE on Wed Nov 30, 2011 8:03 pm; edited 1 time in total (Reason for editing : Spelling)
20Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 2:14 pm
CanberraDave
CanberraDave
Very interested in your dash setup Bushy. Do you have any detail on how it was nade etc. I am looking at something like this to support my Zumo 550.
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
21Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 3:23 pm
walfish
walfish
what about a blue tooth set up, i have a helmet with built in blue tooth (stereo) which i link up to my mobile phone, can take calls one button push listen to music and depending on the type of phone you have listen to radio.
keeps me smiling
22Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 4:10 pm
You blokes really amaze me....the things you can put on a K. I suppose the next thing on bikes will be a reversing camera. I get in trouble from my wife when I reverse my bike. I make beep, beep noises...doesn't need any installation instuctions!
23Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 7:18 pm
bushyintas
bushyintas
88KE,
You're right about the hoses, Vacuum cleaner hase with crevice tools from same vacuum cleaner. Hose runs from scoops mounted under front of fairing, cool air to my knees, Vents also mounted on each side just like the ones sometimes found on the LT.
WATERPROOF MP3 FM RAIO Img_0910
WATERPROOF MP3 FM RAIO Img_0911
Regards Bushy
24Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 7:39 pm
bushyintas
bushyintas
CanberraDave,
The dash was purchased from the USA, on e-bay, it's off a LT, bolted straight on, between the screen and the fairing, uses the same screws as the windscreen ,fitted out to what you see now, Oil pressure gauge on right, water temp on left, 12 volt power supply, radio in centre (had to cut hole to fit but looks ok),map light was with the unit, switch on far right is for power to the radio amp that is installed internally to the dash with its volume control that can be seen below it (chrome knob). My bike already had the LT screen fitted when purchased, raised contour to the base of the screen to allow room for the dash, screen was cut down by previous owner, thats another story.
WATERPROOF MP3 FM RAIO Img_0912
WATERPROOF MP3 FM RAIO Img_0913
Regards Bushy
25Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 7:44 pm
I was eyeing one off on fleabay US a while ago. You must have been the one who beat me to it.
26Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 7:49 pm
bushyintas
bushyintas
You've got to be quick, there seems to be more and more K bikes being restored to there former glory, or is that just the way it seems now that I own one, once you have purchased a type of vehicle you seem to see them everywhere.
regards Bushy
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
27Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 8:14 pm
Those scoops are very neat Bushy, great find. Am I right in thinking those little pods inside them are LEDs ? If so can you post a pic of them running? I'm thinking of installing them. Bike viz bullets they're called.
88KE
PS that bike is waaay too clean! Must be all that practice polishing fire engines!!
K75RTP - 1994
28Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 8:41 pm
bushyintas
bushyintas
Lucky I'm not Blakey or my bike would be red too.Very Happy
Heres a pic of the led's, indicator bulb sockets also changed to stop/tail type, the bigger you look the more you are left alone.
WATERPROOF MP3 FM RAIO Lights10
Regards Bushy
29Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 9:57 pm
caferacer62
caferacer62
88KE wrote:Those scoops are very neat Bushy, great find. Am I right in thinking those little pods inside them are LEDs ? If so can you post a pic of them running? I'm thinking of installing them. Bike viz bullets they're called.
88KE
I think the little bullet thingo's beside the vents are roo shoo's aren't they bushy?
Man your brave stealing 2 vacuum cleaner parts mate out of the house, breed em tough down in Tassie:D
Must say that your K is a quality looking unit, very nice indeed. Your profile says its an LT is that right, your headlights different to mine i dont have the strip light above the headlight. Sorry if its a silly question, but i'm still getting my head around all the variations.
Bert 2.0
WATERPROOF MP3 FM RAIO 170874
30Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 10:38 pm
Can you post a photo of your headlight, I have never seen one without a park light and now I am curious in the extreme.
31Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 10:43 pm
K Freak, if you enlarge that photo I think you can see that park light.
32Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 10:55 pm
ainsjac wrote:K Freak, if you enlarge that photo I think you can see that park light.
Not Bushys but Caferacers bike.
33Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 11:10 pm
bushyintas
bushyintas
Caferacer,
Roo Shoos... yes, lots of little wallabies around where I live, Little buggers dart out at dusk, you think the've gone past then they dart back under you. Have hit one, like hitting a house brick, installed the ultrasonics they seemto move off the road before you're on top of them.
regards Bushy
Bushy
34Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Nov 30, 2011 11:20 pm
bushyintas
bushyintas
It's An 88 RT, was sold as LT by previous owner but on looking into it I stand corrected, My profile updated too
Regards bushy
Bushy
35Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Thu Dec 01, 2011 1:37 am
caferacer62
caferacer62
K Freak wrote:Can you post a photo of your headlight, I have never seen one without a park light and now I am curious in the extreme.
Will have a look when i get home from the funny farm this arvo. Now i'm not sure if its the same or not.
Bert 2.0
36Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Thu Dec 01, 2011 11:35 pm
caferacer62
caferacer62
Checked my headlight last night. It is the same, has parking light.
The reason i hadn't noticed it is because it doesn't work, must check bulb.
Bert 2.0
37Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Fri Dec 02, 2011 12:17 am
The lights are not on, but someone is home !
38Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Dec 06, 2011 6:42 am
col
col
finally got all my parts together today holes cut in dash install should be complete thursday night
39Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Dec 06, 2011 7:57 am
col wrote:finally got all my parts together today holes cut in dash install should be complete thursday night
Did you go with the one per the original post Col? MAybe you'll stick up some pics of the finished product.
88KE
40Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Dec 21, 2011 6:06 am
col
col
yes went with the original one fitted up works really well just one problem usb lead i bought in town doesnt work but i have replaced it will put pictures after i get it back together easier to take it all off while doing lowering work
41Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Mon Dec 26, 2011 7:36 am
col
col
WATERPROOF MP3 FM RAIO Radio_14
WATERPROOF MP3 FM RAIO Radio_15
radio /mp3 player installed
3.5 stereo socket and usb power socket in left fairing pad i installed there because there was already a hole
usb data socket behind master cylinder installed there for same reason
WATERPROOF MP3 FM RAIO Radio_13
WATERPROOF MP3 FM RAIO Radio_16
just waiting on new speakers to go inside helmet
price breakdown
radio 60(us including postage)
usb socket 20
3.5stereo & usb power socket 20
ariel 20
3.5 stereo plugs x4 10
every thing else i had on hand
it works great and no more trying to get ipod out pocket to adjust volume
42Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Mon Dec 26, 2011 8:00 am
cool
43Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Mon Dec 26, 2011 7:12 pm
BIG D
BIG D
Cool
Very neat col it looks the part.
BIG D
44Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Mon Dec 26, 2011 9:35 pm
Neat Col. Thanks for the pics. A few questions if you dont mind. The lead and helmet fitting, did you have those and does the lead pull out of the usb socket when you stretch the lead?. Will the helmet fitting need to be soldered to the speaker wires?
88KE
K75RTP - 1994
45Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Dec 27, 2011 12:51 am
Col, Will your new set up work near Tamworth where they have both types of music...country AND western ?
46Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Tue Dec 27, 2011 6:57 am
col
col
i drilled a hole in helmet and installed 3.5mm stereo socket from a wall plate available from j car and soldered on a 90 degree plug to speaker wires you can see it in photo the curly lead i stole from my brothers old 2 way radio havent had it pull out yet i also have foam pads to go over speakers i used a plain flat lead before the curly lead and it worked fine
WATERPROOF MP3 FM RAIO Radio_17
WATERPROOF MP3 FM RAIO Radio_18
no the radio will not in work in tamworth as both types of music a prohibited deep purple ,black sabbath,chisel,pink floyd on the flash drive who needs the radio
47Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Dec 28, 2011 12:38 am
Thank goodness Col that you are not a fan of country music. If you were it would not go with that fishnet concept that you made public a while ago.
48Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Dec 28, 2011 5:17 am
col
col
stilettos ,fishnets and cowboy hat not a real good fashion statement
49Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Dec 28, 2011 5:19 am
WATERPROOF MP3 FM RAIO 44271
50Back to top Go down   WATERPROOF MP3 FM RAIO Empty Re: WATERPROOF MP3 FM RAIO Wed Dec 28, 2011 6:08 am
BIG D
BIG D
col wrote:stilettos ,fishnets and cowboy hat not a real good fashion statement
Cool
affraid The mind boggles.
BIG D
