1Back to top Go down   Rear Muguard Extension Empty Rear Muguard Extension Sat Nov 14, 2009 6:36 pm
Hi Folks,
The original K 100 came with a mudguard which stopped short at the area above the clutch actuating mechanism so that a continuous shower of filth and water is directed at the area when we ride in the wet. BMW recognised this in 1994 (it only took ten years), and released an inner mudguard extension which is referred to in the following picture http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?model=K%20100%20RS&prod=071990-011992
Now whilst this part only fits the 4Valve, K1 and K1100 one could make a similar extension from a bit of rubber sheeting say 1/4" or 5 mm thick and bolt it through the rear mudguard at the bottom and that would deflect the crud away from the clutch actuating arm and cable end. Also give the clutch actuating arm and cable pivot a good squirt with aerosol chain lube on a regular basis (when you change the engine oil say) and my bet is there will be no more corroded /stiff clutch actuating arms.
2Back to top Go down   Rear Muguard Extension Empty mudguard extension Sun Nov 15, 2009 12:04 pm
elle
elle
Hi thanks K bike have a mudguard extender from a cb 500 thats now going to be customized!!
read your other postings what does the sun look like? here in uk we saw it for almost 3 days!! and yesterday was a no brainer was wet through before ride even started only bit of me that was dry when i came back was both lower inside legs thanks to the k heat.
Still surprising me with how stable they are in wet much more than a goldwing that was being a prat good job recession has kept farmers from replacing gates or there would be one bad mood goldwing rider whoose insurance would have skyrocketed!!
pete
3Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Mon Nov 16, 2009 12:20 am
Hi Pete,
Well worth fitting one of the front mudguard extender available in the UK for our bikes, stops all the crap spraying back onto the engine.
Weather here is great even on a wet day we get to see blue sky most days AND summer is coming!.
4Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 05, 2010 6:27 am
viney
yeah the weather down under is awesome for riding. Can't beat it!!!!
5Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 05, 2010 3:58 pm
Hi Viney,
The down under thing is a northist comment foisted upon us by those from the northern hemisphere who try to change the facts about who is "on top". We all know that in fact astronomically speaking south is at the top and north is at the bottom. This dates from the time when astronomers started mapping the planets using their telescopes which produce an image where south is at the top. From then on south is shown on the top and north is shown on the bottom. So all of us in Aus and NZ are on top of the planet and all of those poor devils shivering in the north are actually down under Sad
6Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 19, 2010 11:29 pm
viney
hahaha
well either way... down under... on top? that is up for debate but the fact is we have awesome riding weather
7Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Thu Jan 21, 2010 7:49 pm
ReneZ
ReneZ
Some people think they think, but the only think so?? Or if you can't convince them, confuse them. Guess as per K we sdhould be walking upsidedown here up north????? ;-)
Rene
BMW K100 - 1985 (0030029) Scotland Rear Muguard Extension Rain
8Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Fri Jan 22, 2010 4:01 pm
japuentes
japuentes
Hello there, sorry you are all wrong, the ecliptica (eart´s traveling path around the sun) is in a vertical plane, so up and down is always changing ...
Best regards
JAP
9Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 10, 2012 4:38 pm
Paul Friday
Paul Friday
I reckon it's more than just an extender... I find that when riding in what we call a gentle shower (bottom of the ocean with just enough air to remain conscious) there is so much spray from the rear wheel that my left boot gets soaked through.
I'm planning how to add a quarter-circle of plastic plus a mudguard extended. I might do it both sides to keep the crud off the rear caliper and shock as well.
If it works I'll post pictures.
http://www.theostry.com
10Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 10, 2012 5:48 pm
Please do Paul. I'm not quite sure what you mean by a quarter circle of plastic.
88KE
Rear Muguard Extension Ir-log1188....May contain nuts!Rear Muguard Extension Ir-log11
K75RTP - 1994
11Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 10, 2012 9:57 pm
Also stops the snakes from flipping back at you after you run them over.
I think I'll make one too.
12Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Tue Jan 10, 2012 10:18 pm
Ooh a k100 bathtub model is on the way, cant wait to see this.
13Back to top Go down   Rear Muguard Extension Empty Re: Rear Muguard Extension Wed Jan 11, 2012 4:25 pm
ReneZ
ReneZ
Use the part from the 1100, they have an extension that protects the clutch booth/gear switch
Rene
