1Back to top Go down   Spectacular Empty Spectacular Tue Jan 24, 2012 8:45 am
komandoalicante
komandoalicante
Spectacular is the result of changing lamps a box you buy from DealExtreme
This is the control panel before you start
Spectacular Cimg3166r
These lamps, the original with the new cap and without the
Spectacular Cimg3176
With the cap removed or carries lamps
Spectacular Cimg3177
And with the lamps in the new portal
Spectacular Cimg3180f
These are the four lighting
Spectacular Cimg3181t
And these the clock and the check
Spectacular Cimg3184
And the end result
Spectacular Cimg3187
What do you think?
Warning
Alternator light can not be changed
https://picasaweb.google.com/100417997445250027277
2Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 9:24 am
beanoldboy
beanoldboy
What a difference.
http://www.airware.com.au
3Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 9:42 am
Wow that is good looks like I have another thing on the wish list. Thanks Komando
Bikes 2004 K1200GT 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
4Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 11:44 am
club_c
club_c
What kind of lights are you using? What a good difference.
1988 K100RS SE VIN 01477554
5Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 1:58 pm
great result komando .....Spectacular 112350
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OSpectacular Au-log10
6Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 3:21 pm
Very impressive. Have you ridden at night yet? Is there a glare or distracting light from the clocks?
Are THESE the exact bulb you used?
88KE
Last edited by 88KE on Tue Jan 24, 2012 4:14 pm; edited 1 time in total (Reason for editing : Add link)
7Back to top Go down   Spectacular Empty Re: Spectacular Tue Jan 24, 2012 5:15 pm
ReneZ
ReneZ
wouldn't you have had the same effect if you would have taken the green socks of the bulbs?
Greetings from Florida! Having a 'new' K  :cyclops:    Surprised-o:
Rene
BMW K100 - 1985 (0030029) Spectacular Rain
BMW K1200GT - 2003 (ZK01223)
8Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 3:26 am
komandoalicante
komandoalicante
@beanoldboy wrote:What a difference.
@club_c wrote:What kind of lights are you using? What a good difference.
I bought the lamps here
http://www.dealextreme.com/p/t10-1-2w-6500k-70-lumen-5-smd-led-car-white-light-bulbs-pair-dc-12v-5135
88KE wrote:Very impressive. Have you ridden at night yet? Is there a glare or distracting light from the clocks?
88KE
Very impressive. Have you traveled at night yet?
I think not bother, or At Least I do not mind a
Is there a flash of light or distract from the clocks?
The time to look at the clocks is shorter
Are these the exact bulbs you use?
Whether these are
@ReneZ wrote:wouldn't you have had the same effect if you would have taken the green socks of the bulbs?
I do not understand the question.
Incandescent lamps have a green paste on your lamp if you remove the rubber green color is very yellow, green gum that covers the little lamp light passes. And you can not put on new lamps.
9Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 5:01 pm
Lvog57
Once again.... did you ride at night with this new "Christmas tree" ? In my mind, it is too glare to be functional and should be very annoying. I am in the process of doing the same thing. My first test was to remove the green caps from the bulbs and for me, it is too bright. I have ordered some LED today (not expensive) :
http://www.lightexports.com/servlet/the-406/2pcs-1-LED-T10/Detail
I will post the results as soon I receive my order.
10Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 5:16 pm
Please do Ivorg57. I'm very interested in this upgrade as my clocks are too dim at night.
88KE
Spectacular Ir-log11 88....May contain nuts!Spectacular Ir-log11
11Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 5:22 pm
If I can see my clock, it's daytime. If I can't see my clock, it must be night.
12Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 5:37 pm
caferacer62
caferacer62
@RT wrote:If I can see my clock, it's daytime. If I can't see my clock, it must be night.
Spectacular 44271
I'm still trying to figure out where i can get a prescription visor for my helmet to match my glasses bounce
Bert 2.0
Spectacular 170874
13Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 7:23 pm
If you want LEDs try this guy he has done all the homework and got the good ones http://www.kbikeparts.com/
14Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 8:30 pm
K Freak wrote:If you want LEDs try this guy he has done all the homework and got the good ones http://www.kbikeparts.com/
Yes but.... Minimum order for international: $40
I do understand the hassle of shipping internationally, but 4 LEDs for $40 vs 8 for $11 (shipping included) is a big difference. A bubble wrap envelop is all what's needed for the shipping.
I am waiting for the report of my bro (LVog57) to select a solution.
What I want to resolve is the condensation in the instrument pod.
CF
Spectacular Frog15Spectacular Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
15Back to top Go down   Spectacular Empty Re: Spectacular Wed Jan 25, 2012 8:34 pm
Oldgoat
Oldgoat
It certainly took care of any and all moisture problems I was having CF although I did also do a crude venting setup on the back plate...
OG
16Back to top Go down   Spectacular Empty Re: Spectacular Thu Jan 26, 2012 1:37 am
The article I wrote way back on changing the bulbs to Leds and sealing the pod took care of my condensation problem permanently. Plus the illumination level is perfect for the darkest night - no glare.
17Back to top Go down   Spectacular Empty Re: Spectacular Thu Jan 26, 2012 2:36 am
komandoalicante
komandoalicante
@lvog57 wrote:Once again.... did you ride at night with this new "Christmas tree" ? In my mind, it is too glare to be functional and should be very annoying. I am in the process of doing the same thing. My first test was to remove the green caps from the bulbs and for me, it is too bright. I have ordered some LED today (not expensive) :
If you think it's very light might result you get with these LED is the one you want.
For me the result with the LED you have asked is very poor.
And even poorer in blue
regards
SAK3 and komandoalicante is the same person
In March we made a International meeting of BMW motorcycle K in  Spain.
The last meeeting 6ª Editions March 2015
6ª international meeting BMW K
Spectacular 7cnp
18Back to top Go down   Spectacular Empty Re: Spectacular Thu Jan 26, 2012 2:44 am
komandoalicante
komandoalicante
CF
If you buy your LED to DealExtreme Mimino no order.
I ordered 6 LED and something else for 20 € with shipping included
I speak for Spain do not know if you have for you customs fees
Spectacular 7cnp
19Back to top Go down   Spectacular Empty Re: Spectacular Thu Jan 26, 2012 3:30 am
Good post Komandoalicante, you got everyone talking.I cannot make your meeting I am sorry as much as I would like to.
