1 Need K100 Ignition Wiring Plug Thu Feb 23, 2012 7:27 am
jimz49
I was having trouble with my ignition switch a while back and decided the best course of action would be to replace it. As luck would have it I found a replacement on ebay. So today I decided it would a good time to switch the old out and put the replacement in. Much to my surprise when I followed the cable from the ignition switch back to the harness under the tank, I found the plugs (both male and female) had been cut off and the wires soldered together. So here is my dilemma, I need the plug that would be attached to the wiring harness, plus a little bit of wire with it so that I can attach it to my harness. Any help will be much appreciated. I can pay via paypal if that works for you. I posted this request in the buy/sell forum, but not the explanation.
