1Back to top Go down   Change of head lamp bulb on LT Empty Change of head lamp bulb on LT Sun Mar 11, 2012 3:37 pm
sensei
Today I tried to change the head lamp bulb on my 1989 LT, but in vain. I consulted the owners manual, but it only described the procedure for the model without fairing and for the RS.... It seems as I have to dismantle half of the fairing to get access, but it can't be right...or? Hopefully you guys know better, so any suggestion is very welcome.
2Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Sun Mar 11, 2012 5:50 pm
The procedure is similar to the one for the RS model.
3Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Sun Mar 11, 2012 6:29 pm
If you remove the instrument panel (speedo etc) by undoing the electrical connector plug and the holding screws, you can just get enough room to manouvre your hands around and get at the bulb . You may have to take off your screen as well to make it a bit easier.
Study the wire holding clip as it comes off, it only goes on one way
and can be a nightmare for impatient old dudes with bad eyesight.
Change of head lamp bulb on LT 886
4Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Sun Mar 11, 2012 8:04 pm
sensei ...it might be easier if you undid the right hand pocket
about 6 screws
this might give you access to the behind headlight area ..well does for me on the rt
5Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Sun Mar 11, 2012 8:33 pm
Avenger GT
Avenger GT
Charlie is right, take out one of the fairing pockets, right hand one if you are right handed, left if you are left handed. It's still a bit fiddly but you get enough elbow room to get in there.
6Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Mon Mar 12, 2012 12:56 am
col
col
you only need to undo pockets to get to globe that all i do on my lt
1991 k100lt "the enterprise"
7Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Mon Mar 12, 2012 5:36 am
ReneZ
ReneZ
Agreed, just that as a right handed person I would take out the left pocket......Smile
Rene
BMW K100 - 1985 (0030029) Scotland Change of head lamp bulb on LT Rain
8Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Sun Mar 25, 2012 4:24 pm
Maybe mine is different. K100LT I got the bulb out without removing anything. It was fiddly but doable.
9Back to top Go down   Change of head lamp bulb on LT Empty Re: Change of head lamp bulb on LT Mon Mar 26, 2012 5:09 am
sensei
Yes you are right, I also managed to change the bulb without dismantling anything, but it took a lot of time and patience and I guess that persons with large hands will have difficulties here...
