1985 k100RS turbocharged Wed Mar 14, 2012 1:29 pm
banditdog
i have a1985 k100rs turbocharged from the dealer when it was new. The plugs foul out when trying to start it after it sits for 8 hours or more after riding it.The bike has only 29,000 miles and had the 30,000 mile service at 26,000 miles. I have checked the wiring under the tank,computer and cleaned all connections and grounds.I also have checked the temperature sensor and it has the proper ohms .The fuel pump,regulator are also new. After it does get running it will idle at 1000 rmp and go to 1200 to 900 rpm ,up and down. It will not idle steady but rev up ok.I changed out the ecm with one from spare parts.This bike ran good and has not been abused and regular maintenance has always been done.Dielectric grease has been also applied to connections.Air filer is also new, it will start if i use starting fluid when cold and then when warm i think it runs a bit too rich. The gas flows back into the tank with no restriction. I do not see any cracked rubber manifold problems. Could an air leak cause the up and down idle and fouling plugs? thank you i need all the help i can find. This is about to drive me crazy trying to trouble shoot this problem!
