1Back to top Go down   Switch Wiring Empty Switch Wiring Sun Apr 15, 2012 7:11 am
CanberraDave
CanberraDave
Below is a diagram of wiring up a toggle switch to accessories. I have four toggle switches on my dash and two are used - Hazard and spotties. The other two were used for police gear and were just cut off. I want to use them to cable up my radio and intercom to an on/off switch. Problem is the swich has no pin lables and the wiring does not match anything standard. Using the below diagram and assuming pole 4 is closest to the fuel tank I have blue/white, pole 2 is yellow/grey and pole 3 is brown. Can someone let me know what the 3 poles are on a BMW toggle switch as they are not labled and when it gets to the plug it changes color again. On the female side of the plug I have a loop of green/black between poles 3 and 2 and the green black on pole 2 goes off to where it was cut. Green yellow runs from pole 4 and goes to the old police relay. Any help would be much apreciated. Hope this is not too confusing.
Switch Wiring Scion_led_switch_diagram
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
What happens if you get scared half to death twice?
2Back to top Go down   Switch Wiring Empty Re: Switch Wiring Sun Apr 15, 2012 7:50 am
The genuine switches is a three position switch.
In centre position nothing is connected.
If you push down in one end, the center pole being connected to the pole in the opposite side.
eg. If you push the switch down at rear end, front and center pole would be connected.
Illuminated switches have one more pole for the ground connection (brown wire).
Last edited by Inge K. on Sun Apr 15, 2012 8:17 am; edited 1 time in total (Reason for editing : Adding info.)
3Back to top Go down   Switch Wiring Empty Re: Switch Wiring Sun Apr 15, 2012 8:20 am
Inge K. wrote:The genuine switches is a three position switch.
As CanberraDave says, this is a ON/OFF switch with a bulb (The 4 way flashers on my K75 has one and this is a genuine BMW one).
I don't have access to it right now, but yes the switch has to be wired with a + AND a -.
CF
Switch Wiring Frog15Switch Wiring Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Switch Wiring Empty Re: Switch Wiring Sun Apr 15, 2012 9:49 am
CF
I must say I agree that I could have expressed myself a little more specific about the switches.
The switches is basically a three position switch, due to internal mods there is a lot of configurations.
on-off-on.
momentary on-off-on.
momentary on-off-momentary on.
off-on.
Nothing mentioned about a bulb (or just on/off) in CD`s text, but as long it`s a brown wire involved...I assume a bulb is present.
But since it`s a former police, you newer know about the wiring since the switches have other functions...than civilians.
Last edited by Inge K. on Sun Apr 15, 2012 10:57 am; edited 1 time in total (Reason for editing : Adding info.)
5Back to top Go down   Switch Wiring Empty Re: Switch Wiring Sun Apr 15, 2012 11:23 am
Haven`t found anything matching the colour codes, or the wiring description.
Closest one involving a loop is a sirene wiring, which a momentary on-off-on switch grounds the negative side of the coil to the sirene relay.
Switch Wiring Sirene10
6Back to top Go down   Switch Wiring Empty Re: Switch Wiring Sun Apr 15, 2012 6:09 pm
Here is the wiring of the hazard switch. 2 & 3 are power and 4 is ground.
I would assume that the schematic of CanberraDave is ccorrect.
Switch Wiring Switch10
7Back to top Go down   Switch Wiring Empty Re: Switch Wiring Mon Apr 16, 2012 7:15 am
CanberraDave
CanberraDave
Thanks for the help guys. I think Crazy Frog has given me the best bet yet. I will hook it up later this week and see what happens.Switch Wiring 212902
Canberra Dave
00 R1100RT
6/89 K100RT (RIP)
VIN # 0097704
8Back to top Go down   Switch Wiring Empty Re: Switch Wiring Mon Apr 16, 2012 1:54 pm
CanberraDave wrote:I think Crazy Frog has given me the best bet yet.
No doubt about it, since the wiring colours corresponds...it is a older type (w/bulb) hazard switch that`s used in conjunction with the police equipment.
I was to focused at the police model wiring diagrams and the wiring after the connector.
