Lazyboy
Lazyboy
How do the globes come out on the instrument panel? I want to remove the low fuel warning globe and am not sure how. Dont want to force anything. Will it affect anything with this globe removed ?
1984 BMW K100RT
Bikes Name: Lazyboy
nino
Lazyboy wrote:How do the globes come out on the instrument panel? I want to remove the low fuel warning globe and am not sure how. Dont want to force anything. Will it affect anything with this globe removed ?
If you mean how to remove low fuel bulb, its easy, but do it with two fingers, carefully. Slowly left right, left, right, and back, control force! The bulb is inside black shell, so you can replace it. It wouldnt affect anything.
Lazyboy
Lazyboy
Hi Nino, Thanks for the prompt reply. Do I have to loosen the speedos face plate to get to the globe . I presume that the black globe holder does not pull out ?
1984 BMW K100RT
Bikes Name: Lazyboy
ReneZ
ReneZ
No, all the lights are in the centre part (white bit between the two dials when looking from aft. If you have the speedo open (back side off) you look at the back of the dials. There is a centre bit which is practically the same size as the blue flexible connector. this is fitted with a few small screws. You can take it out and all bulbs are fitted in that.
Rene
BMW K100 - 1985 (0030029) Scotland Removing instrument panel fuel warning globe Rain
Lazyboy
Lazyboy
Got the globe out , put the instrument panel back and all is working great !
1984 BMW K100RT
Bikes Name: Lazyboy
ReneZ
ReneZ
Good one! Very Happy
Rene
