1Back to top Go down   Rev counter problem Empty Rev counter problem Fri May 11, 2012 7:48 am
exitpest
exitpest
Hi just got a speedo cluster from a 1985 k100 rs, problem is the rev counter is reading 0 revs on tick over, is there a way of adjusting it to my old bikes revs?
My bike is a k100 1988 8v
Andy
2Back to top Go down   Rev counter problem Empty Re: Rev counter problem Fri May 11, 2012 9:34 am
ReneZ
ReneZ
Give us some more info??
Does the tacho indicates above idle or it doesn't work at all??
Greetings from Florida! Having a 'new' K  :cyclops:    Surprised-o:
Rene
BMW K100 - 1985 (0030029) Rev counter problem Rain
BMW K1200GT - 2003 (ZK01223)
3Back to top Go down   Rev counter problem Empty Re: Rev counter problem Fri May 11, 2012 10:32 am
exitpest
exitpest
Yes the rev counter works, but seems to be 500 revs lower?
Is there a way or calibrating it?
4Back to top Go down   Rev counter problem Empty Re: Rev counter problem Fri May 11, 2012 11:21 am
Rev counter problem Trim_p10
The PCB for the fuel level warning lamp(s) is also different, so need move that over from your old tacho as well.
This is a half moon shaped PCB on the behind of the tacho.
5Back to top Go down   Rev counter problem Empty Re: Rev counter problem Fri May 11, 2012 12:46 pm
ReneZ
ReneZ
A few things; The tacho gets its signal from the ignition coils, so make sure the connectors/contacts of the thin wires under them are properly cleaned (as all other contacts in the system). There can be two issues; the range is wrong which for me means there is an electrical issue in the speedo, or there is a more mechanical issue where the needle has been shifted on the shaft (where's your 'zero'??) or what has happened as well is that the screen print has come loose below the needle and is restricting its movement.
Rene
6Back to top Go down   Rev counter problem Empty Re: Rev counter problem Fri May 11, 2012 1:43 pm
exitpest
exitpest
Well I think I have fixed the issue with your help...... Cool
There is a small pot on the top of the pcb, i adjusted it and it now reads a 1,000 revs at tick over, just as per my last tacho.
Many thanks for your help. Very Happy
Andy
