1Back to top Go down   Rear hub cap Empty Rear hub cap Fri Jul 06, 2012 9:13 am
captaink
captaink
I've acquired a rear hub cap for my bike
Rear hub cap Imag0334
How do i fit it to my wheel?
Rear hub cap Imag0335
Or is it the wrong one........
1989 k 100rs
2Back to top Go down   Rear hub cap Empty Re: Rear hub cap Fri Jul 06, 2012 9:44 am
It will fit, the two tangs in the centre of the cap fit inside the cylindrical bit that is held on by the centre bolt, you may need to "adjust it" by opening the tangs out a bit. But be warned they do have a habit of committing suiside on the motorway and usualy in front of a big truck.
3Back to top Go down   Rear hub cap Empty Re: Rear hub cap Fri Jul 06, 2012 9:54 am
captaink
captaink
Thanks Rick will attempt to "adjust it"
1989 k 100rs
4Back to top Go down   Rear hub cap Empty Rear Hub Cap Fri Jul 06, 2012 12:15 pm
Lazyboy
Lazyboy
The hub cap goes on quite easily as explained by Rick G. Over the years I have been sticking a very small thin thread of good old Prestik along the edge of the hub cap that rests on the rim and it sticks very well without being hard to pull off and have never lost a hub cap.
1984 BMW K100RT
Bikes Name: Lazyboy
5Back to top Go down   Rear hub cap Empty Re: Rear hub cap Fri Jul 06, 2012 1:04 pm
Looks like you got a cap to the K75 three spoke wheel.
K75`s using four bolts on the rear wheel.
K100 4V and K11`s using five bolts.
And because of that it`s different length on the tangs.
6Back to top Go down   Rear hub cap Empty Re: Rear hub cap Sat Jul 07, 2012 5:36 am
ReneZ
ReneZ
Same is used for the older K100's - no centre bolt.
Rene
BMW K100 - 1985 (0030029) Scotland Rear hub cap Rain
7Back to top Go down   Rear hub cap Empty Re: Rear hub cap Sat Jul 07, 2012 3:37 pm
Yes Rene, all monolevers use only four bolts.......
but the hub cover is different on a three spoke than a Y-spoke.
8Back to top Go down   Rear hub cap Empty Re: Rear hub cap Sat Jul 07, 2012 7:24 pm
yep confirmed ...still looking for one
9Back to top Go down   Rear hub cap Empty Re: Rear hub cap Mon Jul 09, 2012 5:45 am
captaink
captaink
I've just measured the cap i have - 53mm length tangs, the one I apparently need is 33mm.
I figured that this will be about right, it stuck out about that much when I tried to fit it.
It'll be tomorrow before it arrives, so I've got a little time to clean the rear wheel to make it the same colour as the newish cap. Laughing
1989 k 100rs
