1 Rattlng noise from gearbox area on 1985 K100RT Thu 28 Jun 2012 - 10:49
STEVE1959
There is a rattling noise coming from the gearbox area on my K100RT when it is cold, once the engine warms there is no noise. The bike performs nicely with no vibration other than what I would think is normal. I have replaced the rubber cushions in the alternator drive coupling which were pretty worn and the noise is still there. I mentioned this to k75cster and he said it is probably the output shaft rivets coming loose as this is a common problem on early bikes that only have six rivets the later bikes having twelve. There is about 40mm backlash when you move the rear wheel back and forward with it in gear. What is needed parts wise to convert to the later set-up and which model bikes would have the upgraded parts?
