1Back to top Go down   Really stuck Brembo piston Empty Really stuck Brembo piston Thu Jul 12, 2012 2:52 pm
ali2908
ali2908
I have taken apart the front calipers as only one piston was working properly after sitting for 12 years, but I have one which will not budge. I have soaked it in hot water and tried using my airbrush compressor which freed the other three no problem ( quite spectacular when the first piston shot out of the sink) do you think I just don't have enough pressure to free it, or is there anything else to try?
Any help appreciated Smile
Ali
2Back to top Go down   Really stuck Brembo piston Empty Re: Really stuck Brembo piston Thu Jul 12, 2012 3:44 pm
Make a adaptor, fit a grease nipple..........messy, but functions.
3Back to top Go down   Really stuck Brembo piston Empty Re: Really stuck Brembo piston Thu Jul 12, 2012 3:52 pm
ali2908
ali2908
Don't know if would be able to make something like that
4Back to top Go down   Really stuck Brembo piston Empty Re: Really stuck Brembo piston Thu Jul 12, 2012 4:45 pm
Did mention a adapter, since remember doing this on different old cars and used grease nipples that I got laying around.
But a bit search, grease nipples which fits the threads where the tube connects is available (M10x1,0).
Use some teflon tape around the threads, and be sure to clean away all grease afterwards.
Grease nipples.
5Back to top Go down   Really stuck Brembo piston Empty Re: Really stuck Brembo piston Thu Jul 12, 2012 5:47 pm
ali2908
ali2908
I'll look in to that, thanks.
6Back to top Go down   Really stuck Brembo piston Empty Re: Really stuck Brembo piston Fri Jul 13, 2012 4:14 pm
ali2908
ali2908
managed to get it free with a bigger compressor! Very Happy Very Happy Very Happy Very Happy Very Happy
7Back to top Go down   Really stuck Brembo piston Empty Really stuck Brembo piston Fri Jul 13, 2012 8:30 pm
Bigger = better. Well done mate, now you will have to buy yourself a bigger compressor in case it happens again. That's always my excuse to go shopping
