1Back to top Go down   Gear position switch Empty Gear position switch Fri Jul 20, 2012 5:44 am
giles4060
giles4060
Has anyone got a couple of spare pins and a spring for the gear position switch. One spring had broken and lost a pin when it flew out at 120mph when I took the cover of. Would rather not replace the whole switch.
Giles
K100 RS 1991
R80 GS 1990
2Back to top Go down   Gear position switch Empty Re: Gear position switch Tue Jul 24, 2012 5:51 pm
twincarb
twincarb
I would have loved to have said yes not a problem I have one downstairs.... but I binned my old switch a week ago because I couldn't see a use for it having replaced the one that I broke!
Sorry
Yamaha Thundercat
Gear position switch 169042Gear position switch 169034
3Back to top Go down   Gear position switch Empty Re: Gear position switch Tue Jul 24, 2012 6:29 pm
giles4060
giles4060
twincarb wrote:I would have loved to have said yes not a problem I have one downstairs.... but I binned my old switch a week ago because I couldn't see a use for it having replaced the one that I broke!
Sorry
Sad I only need one of the springs now after finding the two pins on the garage floor.
Giles
K100 RS 1991
R80 GS 1990
4Back to top Go down   Gear position switch Empty Re: Gear position switch Fri Jul 27, 2012 7:24 am
They are only little springs try a flic a bic lighter spring, might be the same size
5Back to top Go down   Gear position switch Empty Re: Gear position switch Fri Jul 27, 2012 10:39 am
giles4060
giles4060
K75cster wrote:They are only little springs try a flic a bic lighter spring, might be the same size
Tried a couple but they are to long or wide. I could try cutting them down but need to get it right first time as both M4 screws sheared on removal and to small to extract so will end up gluing it back on for the final time.
Giles
K100 RS 1991
R80 GS 1990
6Back to top Go down   Gear position switch Empty Re: Gear position switch Fri Jul 27, 2012 12:27 pm
get an old speaker ....(bigger the better ) and drag it round the floor
the magnetism can find amazing things ...but more important the things you might not be able to see first glance
just a suggestion
7Back to top Go down   Gear position switch Empty Re: Gear position switch Tue Jul 31, 2012 6:05 pm
Giles,
Whilst searching for something else, I came across an old faulty gear position switch. The fault is in the encapsulated wiring at the top of the switch but the lower part, springs and pins are OK.
I've cleaned the spring sockets and pins, DeoxIT of course, and it's showing good contact between the pins and the central earth contact.
If you want it PM your address and I'll put it in the post.
To test the assembled switch, here is the switching logic:-
There are 4 wires,
A.....yellow/blue
B.....yellow/black
C.....yellow/white
E.....brown (earth)
1st...............B C... connected to E
Neutral.......A B C... to E
2nd............A... C... to E
3rd...................C... to E
4th............A B...... to E
5th...............B...... to E
8Back to top Go down   Gear position switch Empty Re: Gear position switch Tue Jul 31, 2012 6:23 pm
giles4060
giles4060
charlie99 wrote:get an old speaker ....(bigger the better ) and drag it round the floor
just a suggestion
Good idea Charlie.....except the pins are not magnetic. It was a hands and knees job....but found both of them. Spring was broken but seems I may have been offered a replacement.
Giles
K100 RS 1991
R80 GS 1990
9Back to top Go down   Gear position switch Empty Re: Gear position switch Tue Jul 31, 2012 6:24 pm
giles4060
giles4060
sidecar paul wrote:Giles,
There are 4 wires,
A.....yellow/blue
B.....yellow/black
C.....yellow/white
E.....brown (earth)
Fantastic.....and thanks for the additinal info.
Giles
K100 RS 1991
R80 GS 1990
10Back to top Go down   Gear position switch Empty Re: Gear position switch Wed Aug 01, 2012 4:32 pm
twincarb
twincarb
its a bit of closing the door after the horse has bolted.... my basement floor/workshop was just plain concrete i was always looking for bits that fell off the worktop etc... I have now painted the floor a light brown type colour not only is the room brighter but i can normally find the bits that i dropped...
Yamaha Thundercat
11Back to top Go down   Gear position switch Empty Re: Gear position switch Thu Aug 02, 2012 7:44 am
giles4060
giles4060
twincarb wrote:its a bit of closing the door after the horse has bolted.... my basement floor/workshop was just plain concrete i was always looking for bits that fell off the worktop etc... I have now painted the floor a light brown type colour not only is the room brighter but i can normally find the bits that i dropped...
Once bits stop breaking, dropping off, leaking, ratlling etc.. on the K painting the garage floor is my next job. I painted both the floor and the walls in my old garage and youre right it makes a huge difference. Just not getting dusty every time you kneel down is worth the trouble alone.
Giles
K100 RS 1991
R80 GS 1990
12Back to top Go down   Gear position switch Empty Re: Gear position switch Thu Aug 02, 2012 3:32 pm
What, no carpet!
13Back to top Go down   Gear position switch Empty Re: Gear position switch Thu Aug 02, 2012 3:47 pm
Gear position switch 44271
14Back to top Go down   Gear position switch Empty Re: Gear position switch Thu Aug 02, 2012 11:47 pm
Rjtrucker
Why extract? I had to drill and retap the 2mm screws that hold my front break light switch in place. Better to do that then glue it back.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
