1Back to top Go down   #2 injector getting too much sun? Empty #2 injector getting too much sun? on Thu Sep 06, 2012 2:48 pm
zaubertuba
zaubertuba
Number two seems a little tan:
#2 injector getting too much sun? Inject10
Engine seems to be running fine...should I be concerned?
1985 K100RS
2Back to top Go down   #2 injector getting too much sun? Empty Re: #2 injector getting too much sun? on Thu Sep 06, 2012 3:01 pm
@zaubertuba wrote:...should I be concerned?
I would be more concerned about the fuel hose............
which looks rather old and twisted (the manufacture date should be printed on it).
The discoloured injector is caused by a (previous?) minor leak at the o-ring.
3Back to top Go down   #2 injector getting too much sun? Empty Re: #2 injector getting too much sun? on Thu Sep 13, 2012 12:49 pm
Rjtrucker
Is the injector discolored or is it a different injector then original. I have had a few different color injectors here for cleaning. It might have been changed at some time. Also be sure if the o-ring was leaking it was replaced with one that can handle ethanol. Ethanol is destroying the old o-rings. I have replace ment o-rings avaliable for anyone removing their injectors. I also have replace ment screens avaliable. It was posted a while ago about a fuel leak from the o-rings causing a fire. So be careful and if you replace them use lube when you install them so as not to tear them.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
