colinijohnson
colinijohnson
Bad day today - firstly I dropped the bike on the toolbax, cracking the fairing!
Secondly - I was on a mission to clean all connections - I carefully removed the speed sensor from the rear bevel and the noticed a small washer clung to the magnetic. Not being very apt or technical, I assumed the washer went on the end of the sensor, and put it all back on!
MMm I think the washer was off the allen fixing bolt, and guess what?? my speedo now wont work!
I took it off and now can't see the washer, plus the sensor rubber looks slightly worse for wear too.
Please help - Is it best to just try a replacement sensor? (I notice BMW have discontinued now) - will the washer in the bevel cause a problem? will it drain out - or should I replace the bevel (I have a spare).
Or have I missed a trick here ?
Thanks for any help
Colin
Toto_jp
You maybe lucky and the washer is sitting in the bottom of the final drive ,personally Id take the FD out to retrieve it ,Good excuse to grease the splines and fresh oil in the FD. Try cleaning the sensor and connections before you chase a new/secondhand one
cheers Tony
K100 RS 1986
i fear that you might have to break open the bevel box to recover the washer . (probably stuck to one of the vanes of the hall sensor rotating fingers internal )
isnt too hard to do
but untill you recover the washer dont plan using it
HELP - I've messed up my speed sensor Pictur29
Halo
Halo
Oh no yes you need to pull the FD apart for sure Rolling Eyes
Halo
84 K100RS 0014803
93 FZR1000 EXUP
You could try fishing it out with a magnet or a small hook both from the top and the bottom if the washer fits out the bottom so much the better, other than that just going fishing is a good Idea, helps cool the heels
If you pour some petrol down the hole you may wash it out but I would be taking the drive apart and definately not riding it till it's out and in your hand.
7Back to top Go down   HELP - I've messed up my speed sensor Empty job sorted - thanks Tue Oct 23, 2012 8:53 pm
colinijohnson
colinijohnson
thanks for all the advice
I flushed the diff, and it came out!
The speedo seems to work ok too (although it climbs in speed, but slow to descend-?)
Colin
First thing I would try with the slow to react is to lube it VERY sparingly with a light machine oil like for a sewing machine.
Halo
Halo
Great work Colin
84 K100RS 0014803
93 FZR1000 EXUP
Great team effort guys, this is what the forum is all about, top job all.
HELP - I've messed up my speed sensor 10_x_110
