1Back to top Go down   K75 RT fork springs Empty K75 RT fork springs Fri Oct 26, 2012 5:07 pm
chrish8846
I'm replacing my leaking front fork seals and when I pulled the upper cap and removed the upper spring it is a progressive type spring and the fork seal had red Locktite on the seating flange. Is this standard or has someone already been into the front forks??
Chris Hammond
1985 K100 RT sold
1992 K75RT still in Fixing mode
2Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Fri Oct 26, 2012 11:50 pm
progressive fork springs are a personal preference, the P/O may have decided to try firmer front suspension or simply thought to try em to counter spring sag. The seals may have been removed and permatex or locktite used to reseat the seals rather than take a chance they would leak past the base on the legs as apossed to leaking past the tubes. So may be a fussy pre/owner or a cheap insurance job or is that assurance job
3Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Fri Oct 26, 2012 11:59 pm
possibly just to hold the seals into the legs chris (isnt there circlips in there somewheres crikey ive forgoten already )....who knows ..
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OK75 RT fork springs Au-log10
4Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Sat Oct 27, 2012 12:11 am
Showa forks did have progressive springs from factory.
And yes Charlie...they did have circlips.
But the red globb sounds suspicious..............
5Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Sat Oct 27, 2012 12:20 am
I'd be more intrigued then suspicious, did he do it to stop a leak or did he do it to avoid a leak? one is on the front foot and the other on the back foot
6Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Sat Oct 27, 2012 1:03 pm
chrish8846
Both forks went back together fine, some pitting on the tubes that I was able to get to look pretty good. PO had bike for 10 years but got into a car/bike collision and damaged the rear tail section. I'm not so sure he was the one that did the fork work as he bought a K100 to swap frames on to his K75. Once into it he found that OOOPS that will not work and just left both bikes 75% disassembled, that's when I bought them.
Also my Clymer manual says 420cc for empty forks on a 92, correct? and it has circlips and they are Showa forks.
Chris Hammond
1985 K100 RT sold
7Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Sat Oct 27, 2012 2:12 pm
@chrish8846 wrote:Also my Clymer manual says 420cc for empty forks on a 92, correct?
Yes, 420 ml is the correct amount when the fork has been dismantled.
8Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Sat Oct 27, 2012 2:47 pm
chrish8846
Chris Hammond
1985 K100 RT sold
9Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 9:03 am
bohumil
bohumil
hello, my fork .. The 100 rt 1984th I do not know the content of the oil. Please advice.K75 RT fork springs 134951
http://www.boxermorava.cz/
10Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 9:05 am
bohumil
bohumil
ShockedK75 RT fork springs 135000
11Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 9:20 am
Avenger GT
Avenger GT
For a RT 360ml for each leg.
12Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 10:43 am
bohumil
bohumil
think the same amount as in a conventional fork ...
13Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 11:16 am
Hi Bohumil!
As Avenger says 360 ml is the correct amount, which is used on all K100`s with a fairing (exept RS models with a sport fork).
On the naked K100 the amount is 330 ml.
Here you can download the factory manual.
14Back to top Go down   K75 RT fork springs Empty Re: K75 RT fork springs Tue Nov 13, 2012 2:34 pm
bohumil
bohumil
o.k. I give 360 ml. I just plug it seems non-standard
