1Back to top Go down   REBUILDING THE CENTRE STAND Empty REBUILDING THE CENTRE STAND Tue Oct 30, 2012 10:59 pm
japuentes
japuentes
Hi there, so as expected it happened, the center stand gave up, fortunately at home
returning from a short trip with no baggage.
Taking advantage of the you tube videos on how to lift your bike without breaking your
back or the bike, I was able to rise up the bike by myself
(wife watching of course) so only minor cosmetic damages on the fairing and scratches on my pride.
This the photo of the broke center stand
REBUILDING THE CENTRE STAND P7050510
Detail of the failure and 24 years grim
REBUILDING THE CENTRE STAND Ac79afd83e1d874d0ae8642ca0d979502ff2a843edc38a7248736de84aa6ab2f6g
Had to decide between repairing and changing, as neither the bend pipe business nor
spares importing one are good around here, I decided to modify the broken one
and transform it in to a K1100 style one.
As mentioned in the corresponding treat, I want to make a 3d model of the bike, so
this would be the first part to be modeled.
These are the models of the original and the modification.
REBUILDING THE CENTRE STAND Modelo12
REBUILDING THE CENTRE STAND 5226e7d585c906099ef32177fbd1007120e19f09638bb96ba524bf39d456a9566g
Using the models the length of the new supports an dimensions of the supplements required for the upper tops of the
stand were determined, in order of get a stand inclination of around 3 degrees to achieve stability and easiness at dismounting. Also interferences with rear
wheel and exhaust system were checked.
REBUILDING THE CENTRE STAND 42e3d336987380467097a4fa8d5b9f0e9f67ff11d57b515ae8be5348f6b351e66g
Check the fitting and interference
REBUILDING THE CENTRE STAND B5ec20149afc70d144f045c09b1f25712914afb9ad63c3066f3b44db10189c596g
REBUILDING THE CENTRE STAND Caa9991dc89dd3b800fe227f9da2510600ac77a74d8496c0ab8bacf72c11e5df6g
Cutting, fitting
and welding
REBUILDING THE CENTRE STAND C0a52e748d809d0a64346a41af850ab3122fb9a68caa2525e91be3ff5704e0e56g
And finally
REBUILDING THE CENTRE STAND 2352d4524963ad5657824b20493653f5836c4b02ba01b6db2482d87125189f6f6g
REBUILDING THE CENTRE STAND 80160c87a254423858eec885f447128b47ec075493db944ca668a82ddf0cfce36g
REBUILDING THE CENTRE STAND 363ceeee551dabfcf2185c2ba546292c4e764856b00f1435ec54ae8588ebe76a6g
REBUILDING THE CENTRE STAND 720554017f16d7f82a12abb178be1ca54fdd6c60b3825f680fcca1dd09e08f2d6g
REBUILDING THE CENTRE STAND 8f5e9c010b78ef9060662bdb3898c357e253d2b707eaa2a8ea57127e5716c8836g
REBUILDING THE CENTRE STAND 1cf2169730b5b8951d232cfde7e0ae196f577c1b5912d0701ef484b6436c281c6g
REBUILDING THE CENTRE STAND C7a31bf5228a95bdf8e18c71d8089478f5eb3098f4f261ddfe700f6367d1c82f6g
Ready to go
REBUILDING THE CENTRE STAND 5137e3a4f6acea22782fe7b4ca0b616823c89d01d48cfacbba3f5143f1774bba6g
Hope this helps
Best regards
JAP
Last edited by japuentes on Wed Oct 31, 2012 12:45 am; edited 8 times in total (Reason for editing : no draft option on new topics)
REBUILDING THE CENTRE STAND 2854237993 1988 K100RS SE/ABS
2Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 1:31 am
Very good work Jap a 3D model sure makes it easier to see the finished product.
Bikes 1998 K1100 LT, 1993 K75 RT, 1996 K75RT, 1986 K75 GS, 1979 Z1300 Kawasaki
3Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 1:44 am
excelent work jap ...thats a great "how to" REBUILDING THE CENTRE STAND 112350
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OREBUILDING THE CENTRE STAND Au-log10
4Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 2:27 am
That is very good and it makes sense. Is it just as easy to get the bike onto it?
And I like your heatsheild anti-vibration device.
rossco
5Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 2:52 am
nino
Nice job Jap. I had a first type center stand 1983 which broke 2 - 3 times. Than switch to newer stronger one (1986), also curved at the bottom.
I was worried about corosion and grime inside tubes so removed plastic caps and injected graphite grease inside the tubes and pressed caps back. Center stand still in place looks OK. Maybe grease will help to reduce corrosion.
6Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 4:42 am
thinking outside the square, great effort and top job, nice graphics,
certainly helps to visualise your project prior to commencement.
are your side covers (under seat),engine fairings and wheels stock issue for that year and model ?. looks very similar to the 1100 setup.
I think it was Rick G who mentioned a set of 3 spoke wheels on ebay , they look quite smart on your bike.
what colour is your bike.
Another interesting note , when I had my 100lt checked for rego , the inspector said it had an RS chassis number , scratched my head and suggested it was an LT, he insisted that it was RS, does anyone know if the frames are identical?
especially when you look at JAPs cosmetics.
Struggling to remove my centrestand last weekend( 87 RT), allen bolts wont loosen. Worried I'll snap an allen key, any suggestions.Cold treatment is on my mind. Thanks,
cheers Ed.
REBUILDING THE CENTRE STAND 10_x_110
7Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 5:34 am
They are interchangeable. Someone probably didnt want an RS any more and changed it or the frame was bent and changed for a secondhand one. Being as the first K100 are almost 30 years old there are a heap out there that aren't what the papers say they are.
8Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 6:07 am
Nice design and good result Jap.
I also injected 'Rustcheck' oil inside the tubs. Rustcheck is a water repellent used here in Canada to protect the cars bodies from salt and corrosion.
I was also thinking of doing a 3D model of the bike, but this is a huge project.
What kind of software are you using? It looks like SolidWorks...
CF
REBUILDING THE CENTRE STAND Frog15REBUILDING THE CENTRE STAND Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
9Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Wed Oct 31, 2012 10:05 pm
Avenger GT
Avenger GT
vlsuzuki wrote: thinking outside the square, great effort and top job, nice graphics,
cheers Ed.
Heat them. There is thread lock on them. I found out the hard way after I chewed the head off one of them trying to remove it. Ended up welding a 17mm nut to it and it came out no problem. I took a gas torch to the other one and it flew out.
10Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 5:50 am
Thanks Avenger , I will give it a go, and let you know.
11Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 2:49 pm
japuentes
japuentes
@Rick G wrote:Very good work Jap a 3D model sure makes it easier to see the finished product.
Thanks Rick
Best regards
JAP
12Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 2:50 pm
japuentes
japuentes
@charlie99 wrote:excelent work jap ...thats a great "how to" REBUILDING THE CENTRE STAND 112350
Thanks Charlie
Best regards
JAP
13Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 2:52 pm
japuentes
japuentes
rossco wrote:That is very good and it makes sense. Is it just as easy to get the bike onto it?
rossco
Hi there, the mountibg is more "crispy" than the old one also feels faster.
The anti-vibration also holds the shield
Best regards
JAP
14Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 2:57 pm
japuentes
japuentes
Hi, I think that the fairing is original but the rims are a mod. afther a crash, regarding the color I asked at the paint shop for the nearest to black dark blue they had, really dont know name or RAL.
Best regards
JAP
15Back to top Go down   REBUILDING THE CENTRE STAND Empty Re: REBUILDING THE CENTRE STAND Thu Nov 01, 2012 3:08 pm
japuentes
japuentes
@Crazy Frog wrote:Nice design and good result Jap.
CF
Hi and thanks
Regarding the corrosion, I noticed that most of the thickness loss at the failure point was due to external wear caused by the rolling over the ground during mounting and unmounting. This rolling area is also one of the most stressed parts of the stand, so I believe that eventually they will fail even if there is no internal corrosion.
The model is made in autocad, and yes the bike model is very huge proyect, I´ll make some measures during the nex spline lube.
Best regards
JAP
