1Back to top Go down   next problem Empty next problem Thu Nov 15, 2012 8:16 pm
darren 08
darren 08
when i was loading the bike onto trailer we felt the handlebars loosen i just tried to tighten em up and the screw broken ive seen this happened in other threads seem to be a weak spot is there aftermarket replacements? im on ebay sourcing replacements but will they have the weakness i wonder:?:
2Back to top Go down   next problem Empty Re: next problem Fri Nov 16, 2012 11:20 pm
club_c
club_c
What broke exactly? An Allen head bolt? If so, can you not just replace the broken bolt?
1988 K100RS SE VIN 01477554
3Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 9:08 am
darren 08
darren 08
the bottom screw broke the one that goes through the yoke im going to see if i can get it welded or fixed in someway
4Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 1:34 pm
club_c
club_c
I can't even picture what you mean. BTW can you update your profile with year and model? It will help us know what advice to give. If you can post a pic of the broken 'screw' (tho I suspect it is a bolt) it would help.
5Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 2:26 pm
club_c wrote:I can't even picture what you mean.
This one, I`ll guess:
next problem Styre10
6Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 2:43 pm
darren 08
darren 08
thats Very Happy the one
7Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 2:46 pm
darren 08
darren 08
i had updated my profile already as far as im aware anyway
8Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 3:03 pm
darren 08 wrote:i had updated my profile already as far as im aware anyway
Try one more time.........
9Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 4:36 pm
club_c
club_c
darren 08 wrote:thats Very Happy the one
No weld. Replace with new or used.
10Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 4:59 pm
something like this....I agree do not weld...would be disappointing to have the weld come undone at speed.
next problem Sany0143
KKlompy next problem 2854237993
next problem Au-log10
11Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 5:25 pm
It's almost certainly broken off the threaded portion at the step.
I'd drill and tap the end 8mm and fit an 8mm stud........but first I would take the easy option and look for a used one on e-bay.
I recently bought a top yoke complete with the handlebar clamps for £8, 'buy it now' price.
12Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:08 pm
darren 08
darren 08
welding just an idea lol ill look on ebay again but have had no luck so far as for the ones in the pic where did you get em and what are they off:D
13Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:14 pm
walfish
walfish
Rattled my cage there with the date on your pic. Klompy, bit futuristic for us this side of the globe. :silent:
next problem Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
14Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:20 pm
darren 08
darren 08
yep paul threaded portion is where it broke
15Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:24 pm
If I recall correctly it was ReneZ who broke this screw.
Check this one for $26.25
There are few triple tees for sale in the UK. If you contact the seller he may have the screw and sell it to you.
Klompy, the picture in your signature was my avatar few years ago. Very Happy
next problem Frog15next problem Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
16Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:27 pm
Just thinking about it darren, the handlebars probably weren't loose. They are rubber mounted.
May need new rubbers?
17Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 6:30 pm
darren 08
darren 08
they seem okay but you are right i should replace em anyway
18Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 8:20 pm
ungaas wrote:Rattled my cage there with the date on your pic. Klompy, bit futuristic for us this side of the globe. :silent:
yep about 10 to 12 hours ahead, when I was in Saudi we used to celebrate new years a dozen times in line with peoples home countries.....on the bad side I am at work tomorrow morning and you are all still celebrating Sunday:(
19Back to top Go down   next problem Empty Re: next problem Sat Nov 17, 2012 8:22 pm
It is ok to be special....What a Face
just found this...
http://www.ebay.com.au/itm/1-Handlebar-Risers-BMW-K75S-K75RT-k75C-K100RT-K100LT-B-/170654836597?pt=Motorcycles_Parts_Accessories&hash=item27bbd22775
next problem Risers10
20Back to top Go down   next problem Empty Re: next problem Mon Nov 19, 2012 7:04 pm
Rjtrucker
Is the bike an RS or RT. I have some risers here. I believe the bottom bolt is what you broke. I have 2 different styles here. If you send a pick of broken one I am sure I have it. I also used washers on my K100 to tighten up the rubber mount.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
21Back to top Go down   next problem Empty Re: next problem Tue Nov 20, 2012 5:10 pm
darren 08
darren 08
hi its an rt sorry for delay in replying
22Back to top Go down   next problem Empty Re: next problem Tue Nov 20, 2012 5:14 pm
darren 08
darren 08
hi again it the bracket thats circled in the diagram above thanks so much for offering to send em on to me thats very kind but you should hold on to em you may need them yourself
23Back to top Go down   next problem Empty Re: next problem Thu Nov 22, 2012 5:21 pm
Here is a set for sale on Ebay
24Back to top Go down   next problem Empty Re: next problem Wed Nov 28, 2012 6:23 pm
darren 08
darren 08
got some bought a k bike for parts well frame engine gearbox clocks are there but all important electrics are gone and of course fairings and boxes gone to but i got my brackets and other bits imay need Very Happy
