1Back to top Go down   Engine oil level Empty Engine oil level on Thu Nov 22, 2012 7:16 pm
My engine output shaft seal is leaking and I decided to make an experiment.
The oil level on the sight glass was almost up to the top of it (Overfilled).
I decided to remove the output shaft seal without removing the oil of the engine and see when it would stop leaking.
The engine is almost perfectly level, and interestingly, the oil stop dripping when the oil level was dead on with the center dot of the sight glass.
What can we conclude from this experimentation?
Don't overfill, and keep the oil level at the dot. Very Happy
CF
Engine oil level Frog15Engine oil level Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   Engine oil level Empty Re: Engine oil level on Thu Nov 22, 2012 8:32 pm
krambo
krambo
I also came to the same conclusion re. oil level window etc. I used to fill mine to just over the dot and it consistently dropped down below the dot on a regular basis. Nowadays I top up to just level with the dot and it hardly ever seems to move. Obviously our old K's have their own method of oil level management - lol Wink
"Aut viam inveniam aut faciam." Engine oil level Uk-bmw12
http://www.its-personal.net
3Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 4:45 am
better add this to the did you know department, under engine management- oil management, now how does one say they did it? emperical observation? much better than the handbrakes observation of "bloody mental shed junkies" although perhaps not too distant an observation.
4Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 6:36 am
Corkboy
Corkboy
Very interesting - as my seal is leaking and the oil is (just) over the top of the sight glass (i.e. overfilled)
If I drain enough oil to bring it to the centre of the sight glass, what are the chances of this stopping the seal leak? (He asks with fingers firmly crossed).
5Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 6:49 am
The leak should stop when the engine is off and the bike is on the center stand.
As soon as the engine is running, it will leak again.
The dot on the sight glass is in line with the bottom of the outside diameter of the seal.
if the oil is up to the top of the sight glass, it's at the level of the bottom of the output shaft.
The repair has to be done ASAP otherwise if the friction plate gets greasy, you will have to replace it. This is not cheap ($200).
6Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 7:45 am
@Corkboy wrote:Very interesting - as my seal is leaking and the oil is (just) over the top of the sight glass (i.e. overfilled)
Somewhere between nothing and sweet FA
7Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 8:34 am
Corkboy
Corkboy
Don't like those odds at all Smile , but about what I was expecting.
Just rang my friendly neighbourhood mechanic (grumpy old b* if the truth be known).
Bike is booked in next week to get the seals done (he will replace the seal, o-ring, and gearbox seal), and will replace the clutch friction plate and springs while he's in there.
Now where did I leave those SWMBO finance request forms (in triplicate) and the special pen with the blood drawing nib. affraid
8Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 1:54 pm
@Corkboy wrote:Don't like those odds at all Smile ,
Probably near the Burdizzo bloodless castrator Sad ...... spending that kind of folding stuff this close to Christmas Engine oil level 694830 You're a very very brave man!
Engine oil level Ir-log11 88....May contain nuts!Engine oil level Ir-log11
9Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 2:14 pm
one of the advantages of the forum is that for folks "willing to give it a go" or with some mechanical knowledge . can benefit from other experiences and troubles, whilst on the repair path .
getting the mechanic to do the work ....kinda takes away that advantage of cost savings ....but "hoorah" for the guys that will do whatever it takes to keep our "old girls " on the road
good luck corkboy ..!
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OEngine oil level Au-log10
10Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 2:56 pm
Hover K100
Hover K100
As part of the useless information section, if you overfill the oil level because you are parked on a river bank and the sight glass is far down in the hull and you are using the Irish method of "to be sure, to be sure" i.e we will add some oil to be sure, then add some more to be sure, the engine will produce great plumes of blue smoke on startup Very Happy
BTW Corkboy, I can pronounce Corkboy the correct Rebel way Very Happy Very Happy. If you get that K running come on down across the border to the Kingdom.
https://www.youtube.com/user/HoverIreland?feature=mhee
11Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 3:05 pm
Corkboy
Corkboy
@Hover K100 wrote:As part of the useless information section, if you overfill the oil level because you are parked on a river bank and the sight glass is far down in the hull and you are using the Irish method of "to be sure, to be sure" i.e we will add some oil to be sure, then add some more to be sure, the engine will produce great plumes of blue smoke on startup Very Happy
It would be a pleasure! I want a go on that hovercraft though.
And the best people come from Cork! https://www.youtube.com/watch?v=Xw2rjaGaHHw&sns=fb
Corkboy
12Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 4:08 pm
Hover K100
Hover K100
It would be a pleasure! I want a go on that hovercraft though.Corkboy
Geez Corkboy you'r some langer, thats a class video Very Happy
13Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 5:14 pm
@Corkboy wrote: And the best people come from Cork! https://www.youtube.com/watch?v=Xw2rjaGaHHw&sns=fb
Corkboy
Can this guy from Cork try it again, but this time jumping sitting on a K bike?
Very Happy
14Back to top Go down   Engine oil level Empty Re: Engine oil level on Fri Nov 23, 2012 7:50 pm
Might be good to see I have heard that a K has the same glide characteristics as a brick.
